I'm trying to add subtitles to a DivX movie via an *.idx/*.sub pair. In VirtualDub, I go to Video -> Filters. Then I click on Add and scroll through the list until I reach VobSub 2.23 (Gabest). I select it, click "Okay", and the configuration window pops up. I click "Open", and I go to the directory and open the *.sub file with no problem. The *.idx file is in the same directory and has the same name as the *.sub file. When I click "Okay", I get an error message box that has the full path to the *.idx file followed by a repeating underscore. Has anyone else here experienced this? If this has been covered somewhere on the site before, I apologize, as I searched this site (as well as the entire web) and couldn't find any information pertaining to it. I may not have looked hard enough.I've also tried uninstalling and reinstalling VobSub, but it didn't work. I'm using VirtualDub 1.4.11, and I'm running it on Windows ME. Also, the contents of the *.idx file are below. Thanks in advance for your help, and please let me know if you need any more information from me.
# VobSub index file, v7 (do not modify this line!)
# To repair desyncronization, you can insert gaps this way:
# (it usually happens after vob id changes)
# delay: [sign]hh:mms:ms
# Where:
# [sign]: +, - (optional)
# hh: hours (0 <= hh)
# mm/ss: minutes/seconds (0 <= mm/ss <= 59)
# ms: milliseconds (0 <= ms <= 999)
# Note: You can't position a sub before the previous with a negative value.
# You can also modify timestamps or delete a few subs you don't like.
# Just make sure they stay in increasing order.
# Settings
# Original frame size
# Origin, relative to the upper-left corner, can be overloaded by aligment
org: 0, 0
# Image scaling (hor,ver), origin is at the upper-left corner or at the alignment coord (x, y)
scale: 100%, 100%
# Alpha blending
alpha: 100%
# Smoothing for very blocky images (use OLD for no filtering)
smooth: OFF
# In millisecs
fadein/out: 50, 50
# Force subtitle placement relative to (org.x, org.y)
align: OFF at LEFT TOP
# For correcting non-progressive desync. (in millisecs or hh:mms:ms)
# Note: Not effective in DirectVobSub, use "delay: ... " instead.
time offset: 0
# ON: displays only forced subtitles, OFF: shows everything
forced subs: OFF
# The original palette of the DVD in PGC#1
palette: 101010, 2b2b2b, ebebeb, ec460d, 7d7d7d, b4b4b4, 0cb4ea, ec15ec, ebff0b, 0e007f, 0c7b0c, 7e2a0e, 0d637c, 7e127e, 7d960c, ebebeb
# Custom colors (transp idxs and the four colors)
custom colors: OFF, tridx: 1000, colors: ec460d, ebebeb, 101010, 2b2b2b
# Language index in use
langidx: 0
# English
id: en, index: 0
# Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x
# alt: English
# Vob/Cell ID: 1, 1
timestamp: 00:00:23:541, filepos: 000000000
timestamp: 00:00:31:291, filepos: 000001000
timestamp: 00:00:46:166, filepos: 000002000
timestamp: 00:00:50:833, filepos: 000003000
timestamp: 00:00:53:500, filepos: 000004000
timestamp: 00:01:00:250, filepos: 000005000
timestamp: 00:01:10:833, filepos: 000006000
timestamp: 00:01:18:125, filepos: 000006800
timestamp: 00:01:23:208, filepos: 000007800
timestamp: 00:01:27:500, filepos: 000008800
timestamp: 00:01:35:166, filepos: 00000a000
timestamp: 00:01:51:125, filepos: 00000b800
timestamp: 00:01:59:791, filepos: 00000c800
timestamp: 00:02:07:041, filepos: 00000d800
timestamp: 00:02:18:166, filepos: 00000e800
timestamp: 00:02:24:125, filepos: 00000f800
timestamp: 00:02:30:416, filepos: 000011000
timestamp: 00:02:46:875, filepos: 000012000
timestamp: 00:02:58:333, filepos: 000013000
timestamp: 00:03:00:416, filepos: 000013800
timestamp: 00:03:05:541, filepos: 000014800
timestamp: 00:03:18:083, filepos: 000015000
timestamp: 00:03:25:458, filepos: 000016000
timestamp: 00:03:37:291, filepos: 000017800
timestamp: 00:03:44:583, filepos: 000019000
timestamp: 00:03:48:708, filepos: 00001a800
timestamp: 00:03:52:666, filepos: 00001c000
timestamp: 00:03:55:541, filepos: 00001d000
timestamp: 00:03:59:541, filepos: 00001e000
timestamp: 00:04:04:375, filepos: 00001f800
timestamp: 00:04:11:750, filepos: 000020800
timestamp: 00:04:18:416, filepos: 000021800
timestamp: 00:04:22:541, filepos: 000022800
timestamp: 00:04:27:125, filepos: 000023800
timestamp: 00:04:32:291, filepos: 000025000
timestamp: 00:04:36:458, filepos: 000026000
timestamp: 00:04:43:125, filepos: 000027800
timestamp: 00:04:49:041, filepos: 000028800
timestamp: 00:04:54:333, filepos: 000029000
timestamp: 00:05:01:666, filepos: 00002a000
timestamp: 00:05:04:666, filepos: 00002a800
timestamp: 00:05:12:125, filepos: 00002c000
timestamp: 00:05:17:083, filepos: 00002d800
timestamp: 00:05:21:500, filepos: 00002e800
# Vob/Cell ID: 1, 2
timestamp: 00:05:42:333, filepos: 00002f800
timestamp: 00:05:47:375, filepos: 000031000
timestamp: 00:05:52:250, filepos: 000031800
timestamp: 00:05:57:333, filepos: 000033000
timestamp: 00:06:03:625, filepos: 000034800
timestamp: 00:06:46:125, filepos: 000036000
timestamp: 00:07:40:416, filepos: 000037000
timestamp: 00:07:44:750, filepos: 000038000
timestamp: 00:07:48:833, filepos: 000039800
timestamp: 00:07:53:458, filepos: 00003a800
timestamp: 00:07:57:833, filepos: 00003b000
timestamp: 00:08:00:916, filepos: 00003c000
timestamp: 00:08:03:208, filepos: 00003d000
timestamp: 00:08:07:708, filepos: 00003e000
timestamp: 00:08:13:625, filepos: 00003f800
timestamp: 00:08:18:750, filepos: 000040000
timestamp: 00:08:21:333, filepos: 000041000
timestamp: 00:08:31:458, filepos: 000042800
timestamp: 00:08:34:666, filepos: 000043800
timestamp: 00:08:38:541, filepos: 000045000
timestamp: 00:08:43:125, filepos: 000046800
timestamp: 00:08:46:541, filepos: 000047800
timestamp: 00:08:49:083, filepos: 000048000
timestamp: 00:08:52:208, filepos: 000049000
timestamp: 00:09:01:500, filepos: 000049800
timestamp: 00:09:08:375, filepos: 00004b000
timestamp: 00:09:11:000, filepos: 00004c000
timestamp: 00:09:18:416, filepos: 00004d000
timestamp: 00:09:20:833, filepos: 00004e000
timestamp: 00:09:26:625, filepos: 00004f000
timestamp: 00:10:24:500, filepos: 000050000
timestamp: 00:10:30:791, filepos: 000051000
timestamp: 00:10:34:666, filepos: 000051800
timestamp: 00:10:39:666, filepos: 000053000
timestamp: 00:10:47:500, filepos: 000054000
timestamp: 00:10:50:916, filepos: 000054800
timestamp: 00:10:54:708, filepos: 000055800
timestamp: 00:11:03:916, filepos: 000056800
timestamp: 00:11:08:958, filepos: 000058000
timestamp: 00:11:16:208, filepos: 000059800
timestamp: 00:11:20:416, filepos: 00005a800
timestamp: 00:11:23:416, filepos: 00005b000
# Vob/Cell ID: 1, 3
timestamp: 00:11:51:875, filepos: 00005c000
timestamp: 00:11:54:708, filepos: 00005c800
timestamp: 00:12:01:125, filepos: 00005e000
timestamp: 00:12:18:000, filepos: 00005e800
timestamp: 00:12:20:083, filepos: 00005f000
timestamp: 00:12:31:666, filepos: 000060000
timestamp: 00:12:38:416, filepos: 000061800
timestamp: 00:12:44:583, filepos: 000062800
timestamp: 00:12:50:958, filepos: 000063800
timestamp: 00:12:58:125, filepos: 000065000
timestamp: 00:13:02:958, filepos: 000066000
timestamp: 00:13:06:666, filepos: 000066800
timestamp: 00:13:13:333, filepos: 000067800
timestamp: 00:13:23:791, filepos: 000069000
timestamp: 00:13:38:083, filepos: 00006a000
timestamp: 00:13:41:666, filepos: 00006a800
timestamp: 00:14:00:250, filepos: 00006b800
timestamp: 00:14:04:500, filepos: 00006c800
timestamp: 00:14:09:583, filepos: 00006e000
timestamp: 00:14:16:125, filepos: 00006f000
timestamp: 00:14:25:000, filepos: 00006f800
timestamp: 00:14:29:458, filepos: 000070800
timestamp: 00:14:38:041, filepos: 000072000
timestamp: 00:14:42:291, filepos: 000073000
timestamp: 00:14:48:250, filepos: 000074000
timestamp: 00:14:55:750, filepos: 000075000
timestamp: 00:15:02:833, filepos: 000076000
timestamp: 00:15:07:000, filepos: 000076800
timestamp: 00:15:10:208, filepos: 000077800
timestamp: 00:15:17:833, filepos: 000079000
timestamp: 00:15:21:791, filepos: 000079800
timestamp: 00:15:27:958, filepos: 00007b000
timestamp: 00:15:31:583, filepos: 00007c800
timestamp: 00:15:37:000, filepos: 00007e000
timestamp: 00:15:42:000, filepos: 00007f000
timestamp: 00:15:46:000, filepos: 000080000
timestamp: 00:15:51:583, filepos: 000081000
timestamp: 00:15:55:791, filepos: 000082000
timestamp: 00:16:02:083, filepos: 000083800
timestamp: 00:16:18:291, filepos: 000085000
timestamp: 00:16:20:666, filepos: 000086000
timestamp: 00:16:42:833, filepos: 000087000
timestamp: 00:16:54:125, filepos: 000087800
timestamp: 00:17:09:833, filepos: 000088000
timestamp: 00:17:15:250, filepos: 000089800
timestamp: 00:17:17:958, filepos: 00008a800
timestamp: 00:17:23:583, filepos: 00008c000
timestamp: 00:17:27:666, filepos: 00008d000
timestamp: 00:17:35:000, filepos: 00008e000
timestamp: 00:17:39:791, filepos: 00008f000
timestamp: 00:17:46:875, filepos: 000090800
timestamp: 00:17:48:500, filepos: 000091000
timestamp: 00:17:52:041, filepos: 000092000
timestamp: 00:17:55:458, filepos: 000093000
timestamp: 00:17:59:291, filepos: 000094000
timestamp: 00:18:02:125, filepos: 000094800
timestamp: 00:18:06:000, filepos: 000095000
timestamp: 00:18:07:958, filepos: 000095800
timestamp: 00:18:12:000, filepos: 000096800
timestamp: 00:18:18:000, filepos: 000098000
timestamp: 00:18:27:791, filepos: 000099000
timestamp: 00:18:35:541, filepos: 00009a000
timestamp: 00:18:41:041, filepos: 00009b000
timestamp: 00:18:45:125, filepos: 00009c000
timestamp: 00:18:49:625, filepos: 00009c800
timestamp: 00:18:54:875, filepos: 00009d800
timestamp: 00:19:00:291, filepos: 00009e800
timestamp: 00:19:04:166, filepos: 00009f800
timestamp: 00:19:14:583, filepos: 0000a1000
timestamp: 00:19:25:458, filepos: 0000a2800
timestamp: 00:19:27:666, filepos: 0000a3000
# Vob/Cell ID: 1, 4
timestamp: 00:19:36:208, filepos: 0000a4000
timestamp: 00:19:39:083, filepos: 0000a5800
timestamp: 00:19:42:416, filepos: 0000a6800
timestamp: 00:19:46:125, filepos: 0000a7800
timestamp: 00:19:49:041, filepos: 0000a8800
timestamp: 00:19:55:833, filepos: 0000aa000
timestamp: 00:19:59:791, filepos: 0000ab000
timestamp: 00:20:06:208, filepos: 0000ac800
timestamp: 00:20:10:750, filepos: 0000ad000
timestamp: 00:20:31:875, filepos: 0000ae000
timestamp: 00:20:35:333, filepos: 0000ae800
timestamp: 00:21:08:750, filepos: 0000af800
timestamp: 00:21:32:500, filepos: 0000b0800
timestamp: 00:21:35:833, filepos: 0000b1000
timestamp: 00:21:38:333, filepos: 0000b1800
timestamp: 00:21:41:041, filepos: 0000b2800
timestamp: 00:21:54:375, filepos: 0000b3800
timestamp: 00:22:00:666, filepos: 0000b4800
timestamp: 00:22:03:958, filepos: 0000b5000
timestamp: 00:22:07:125, filepos: 0000b6000
timestamp: 00:22:12:625, filepos: 0000b7000
timestamp: 00:22:15:750, filepos: 0000b8000
timestamp: 00:22:25:958, filepos: 0000b9000
timestamp: 00:22:30:291, filepos: 0000b9800
timestamp: 00:22:41:750, filepos: 0000ba000
timestamp: 00:22:45:208, filepos: 0000ba800
timestamp: 00:22:50:000, filepos: 0000bb800
timestamp: 00:22:55:791, filepos: 0000bd000
timestamp: 00:23:02:916, filepos: 0000be000
timestamp: 00:23:08:833, filepos: 0000be800
timestamp: 00:23:14:791, filepos: 0000bf800
timestamp: 00:23:20:500, filepos: 0000c0800
timestamp: 00:23:27:291, filepos: 0000c1800
timestamp: 00:23:34:833, filepos: 0000c3000
timestamp: 00:23:39:625, filepos: 0000c4000
timestamp: 00:23:47:583, filepos: 0000c4800
timestamp: 00:23:54:083, filepos: 0000c5800
timestamp: 00:24:04:083, filepos: 0000c6800
timestamp: 00:24:08:041, filepos: 0000c7000
timestamp: 00:24:12:583, filepos: 0000c8000
timestamp: 00:24:15:208, filepos: 0000c8800
timestamp: 00:24:27:250, filepos: 0000c9800
timestamp: 00:24:31:458, filepos: 0000ca000
timestamp: 00:24:34:166, filepos: 0000ca800
timestamp: 00:24:37:291, filepos: 0000cb800
timestamp: 00:24:48:833, filepos: 0000cc000
timestamp: 00:24:52:416, filepos: 0000cd000
timestamp: 00:24:56:750, filepos: 0000ce800
timestamp: 00:24:59:375, filepos: 0000cf000
timestamp: 00:25:04:000, filepos: 0000d0000
timestamp: 00:25:07:458, filepos: 0000d1000
timestamp: 00:25:11:750, filepos: 0000d2000
# Vob/Cell ID: 1, 5
timestamp: 00:25:36:375, filepos: 0000d3000
timestamp: 00:25:48:958, filepos: 0000d3800
timestamp: 00:26:07:541, filepos: 0000d4800
timestamp: 00:26:11:666, filepos: 0000d5800
timestamp: 00:26:15:500, filepos: 0000d6800
timestamp: 00:26:19:000, filepos: 0000d7800
timestamp: 00:26:30:916, filepos: 0000d8800
timestamp: 00:26:53:083, filepos: 0000d9800
timestamp: 00:27:03:625, filepos: 0000da800
timestamp: 00:27:12:250, filepos: 0000db800
timestamp: 00:27:24:041, filepos: 0000dc800
timestamp: 00:27:45:291, filepos: 0000dd000
timestamp: 00:27:51:125, filepos: 0000de000
timestamp: 00:28:15:083, filepos: 0000df000
timestamp: 00:28:19:833, filepos: 0000e0800
timestamp: 00:28:59:208, filepos: 0000e1800
timestamp: 00:29:03:458, filepos: 0000e2800
timestamp: 00:29:07:000, filepos: 0000e3800
timestamp: 00:29:10:666, filepos: 0000e4800
timestamp: 00:29:23:958, filepos: 0000e5800
timestamp: 00:29:28:625, filepos: 0000e7000
timestamp: 00:29:35:708, filepos: 0000e8000
# Vob/Cell ID: 1, 6
timestamp: 00:31:49:166, filepos: 0000e9000
timestamp: 00:31:54:958, filepos: 0000ea000
timestamp: 00:32:33:458, filepos: 0000eb000
timestamp: 00:32:45:750, filepos: 0000eb800
timestamp: 00:32:50:833, filepos: 0000ec800
timestamp: 00:32:52:416, filepos: 0000ed000
timestamp: 00:32:56:000, filepos: 0000ee000
timestamp: 00:32:59:583, filepos: 0000ef000
timestamp: 00:33:20:000, filepos: 0000ef800
timestamp: 00:33:23:750, filepos: 0000f0000
timestamp: 00:33:32:916, filepos: 0000f1800
timestamp: 00:33:40:958, filepos: 0000f3000
timestamp: 00:33:50:208, filepos: 0000f4000
timestamp: 00:34:01:458, filepos: 0000f5800
timestamp: 00:34:11:416, filepos: 0000f6800
timestamp: 00:34:13:625, filepos: 0000f7000
timestamp: 00:34:21:041, filepos: 0000f8000
timestamp: 00:34:26:666, filepos: 0000f9000
timestamp: 00:34:31:833, filepos: 0000fa000
timestamp: 00:34:36:541, filepos: 0000fb000
timestamp: 00:34:49:416, filepos: 0000fc800
timestamp: 00:34:54:291, filepos: 0000fd000
timestamp: 00:35:12:041, filepos: 0000fe000
timestamp: 00:35:22:500, filepos: 0000ff000
timestamp: 00:35:46:625, filepos: 000100000
timestamp: 00:35:56:375, filepos: 000101000
timestamp: 00:36:00:208, filepos: 000101800
timestamp: 00:36:24:708, filepos: 000102800
timestamp: 00:36:32:208, filepos: 000103000
# Vob/Cell ID: 1, 7
timestamp: 00:37:12:541, filepos: 000103800
timestamp: 00:37:20:541, filepos: 000104800
timestamp: 00:37:24:333, filepos: 000105800
timestamp: 00:37:28:041, filepos: 000106800
timestamp: 00:37:33:291, filepos: 000108000
timestamp: 00:37:37:791, filepos: 000109000
timestamp: 00:37:43:875, filepos: 00010a000
timestamp: 00:37:52:708, filepos: 00010b800
timestamp: 00:37:59:666, filepos: 00010d000
timestamp: 00:38:04:041, filepos: 00010e000
timestamp: 00:38:30:083, filepos: 00010f000
timestamp: 00:39:47:375, filepos: 000110800
timestamp: 00:39:51:083, filepos: 000111000
timestamp: 00:39:57:916, filepos: 000112000
timestamp: 00:40:03:125, filepos: 000113000
timestamp: 00:40:10:833, filepos: 000114000
timestamp: 00:40:12:541, filepos: 000114800
timestamp: 00:40:22:791, filepos: 000116000
timestamp: 00:40:29:208, filepos: 000117000
timestamp: 00:40:32:208, filepos: 000118000
timestamp: 00:40:47:458, filepos: 000119000
timestamp: 00:40:55:791, filepos: 00011a000
timestamp: 00:41:00:833, filepos: 00011b000
timestamp: 00:41:22:083, filepos: 00011c000
timestamp: 00:41:24:375, filepos: 00011d000
timestamp: 00:41:36:833, filepos: 00011e000
timestamp: 00:41:41:541, filepos: 00011f800
timestamp: 00:41:47:833, filepos: 000121000
timestamp: 00:41:50:625, filepos: 000121800
timestamp: 00:41:57:083, filepos: 000122800
timestamp: 00:42:00:916, filepos: 000123800
timestamp: 00:42:04:041, filepos: 000124000
timestamp: 00:42:21:500, filepos: 000124800
timestamp: 00:42:23:791, filepos: 000125800
timestamp: 00:42:33:375, filepos: 000127000
timestamp: 00:42:37:708, filepos: 000128000
timestamp: 00:42:57:583, filepos: 000128800
timestamp: 00:43:38:125, filepos: 00012a000
timestamp: 00:43:43:291, filepos: 00012a800
timestamp: 00:43:47:083, filepos: 00012b000
# Vob/Cell ID: 1, 8
timestamp: 00:44:01:208, filepos: 00012c000
timestamp: 00:44:09:166, filepos: 00012d800
timestamp: 00:44:14:041, filepos: 00012e800
timestamp: 00:44:21:250, filepos: 000130000
timestamp: 00:44:26:458, filepos: 000131000
timestamp: 00:44:29:333, filepos: 000132000
timestamp: 00:44:42:333, filepos: 000133800
timestamp: 00:45:15:875, filepos: 000135000
timestamp: 00:45:30:583, filepos: 000136000
timestamp: 00:45:54:000, filepos: 000137800
timestamp: 00:46:02:291, filepos: 000139000
timestamp: 00:46:06:208, filepos: 00013a000
timestamp: 00:46:09:583, filepos: 00013b000
timestamp: 00:46:30:875, filepos: 00013c000
timestamp: 00:46:33:833, filepos: 00013c800
timestamp: 00:46:45:041, filepos: 00013d800
timestamp: 00:46:51:791, filepos: 00013e800
timestamp: 00:47:08:833, filepos: 00013f800
timestamp: 00:47:12:291, filepos: 000140800
timestamp: 00:47:25:041, filepos: 000142000
timestamp: 00:47:31:458, filepos: 000143800
timestamp: 00:47:37:375, filepos: 000145000
timestamp: 00:47:40:958, filepos: 000146000
timestamp: 00:47:59:208, filepos: 000147800
timestamp: 00:48:03:458, filepos: 000148800
timestamp: 00:48:08:750, filepos: 00014a000
timestamp: 00:48:28:875, filepos: 00014b000
# Vob/Cell ID: 1, 9
timestamp: 00:49:05:041, filepos: 00014c000
timestamp: 00:49:09:958, filepos: 00014d000
timestamp: 00:49:17:958, filepos: 00014e800
timestamp: 00:49:22:000, filepos: 00014f800
timestamp: 00:49:27:583, filepos: 000151000
timestamp: 00:49:29:833, filepos: 000152000
timestamp: 00:49:34:291, filepos: 000153000
timestamp: 00:49:45:166, filepos: 000154000
timestamp: 00:49:48:083, filepos: 000155000
timestamp: 00:49:56:125, filepos: 000156000
timestamp: 00:50:07:583, filepos: 000157800
timestamp: 00:50:13:416, filepos: 000158800
timestamp: 00:50:18:166, filepos: 000159800
timestamp: 00:50:28:375, filepos: 00015b000
timestamp: 00:50:34:708, filepos: 00015c000
timestamp: 00:50:58:250, filepos: 00015d000
timestamp: 00:51:03:875, filepos: 00015e000
timestamp: 00:51:09:000, filepos: 00015e800
timestamp: 00:51:17:750, filepos: 00015f000
timestamp: 00:51:27:708, filepos: 000160000
timestamp: 00:51:32:750, filepos: 000160800
timestamp: 00:51:38:125, filepos: 000161800
timestamp: 00:51:45:583, filepos: 000162800
timestamp: 00:52:49:333, filepos: 000163800
timestamp: 00:52:54:208, filepos: 000164800
timestamp: 00:52:59:208, filepos: 000165800
timestamp: 00:53:06:875, filepos: 000166800
# Vob/Cell ID: 1, 10
timestamp: 00:54:13:750, filepos: 000168000
timestamp: 00:54:19:125, filepos: 000169800
timestamp: 00:54:24:958, filepos: 00016a800
timestamp: 00:54:29:416, filepos: 00016c000
timestamp: 00:54:33:208, filepos: 00016c800
timestamp: 00:54:37:875, filepos: 00016d000
timestamp: 00:54:41:750, filepos: 00016e000
timestamp: 00:55:20:041, filepos: 00016f000
timestamp: 00:56:06:291, filepos: 000170000
timestamp: 00:56:10:166, filepos: 000171000
timestamp: 00:56:13:333, filepos: 000172000
timestamp: 00:57:40:958, filepos: 000173000
timestamp: 00:57:55:833, filepos: 000174000
timestamp: 00:58:01:708, filepos: 000175000
timestamp: 00:58:23:541, filepos: 000176000
timestamp: 00:58:27:416, filepos: 000177000
timestamp: 00:59:01:166, filepos: 000178800
timestamp: 00:59:12:541, filepos: 000179800
timestamp: 00:59:17:750, filepos: 00017b000
timestamp: 00:59:29:250, filepos: 00017c000
timestamp: 00:59:33:916, filepos: 00017d000
timestamp: 00:59:44:250, filepos: 00017e000
timestamp: 01:00:50:541, filepos: 00017f000
timestamp: 01:00:54:625, filepos: 000180800
# Vob/Cell ID: 1, 11
timestamp: 01:02:07:416, filepos: 000181800
timestamp: 01:02:11:541, filepos: 000182800
timestamp: 01:02:20:250, filepos: 000183800
timestamp: 01:02:25:875, filepos: 000184000
timestamp: 01:02:33:708, filepos: 000184800
timestamp: 01:02:36:583, filepos: 000185800
timestamp: 01:02:44:041, filepos: 000187000
timestamp: 01:02:49:375, filepos: 000188000
timestamp: 01:02:55:750, filepos: 000189000
timestamp: 01:03:01:833, filepos: 00018a000
timestamp: 01:03:05:041, filepos: 00018b000
timestamp: 01:03:11:375, filepos: 00018c000
timestamp: 01:03:15:625, filepos: 00018c800
timestamp: 01:03:18:875, filepos: 00018d800
timestamp: 01:03:25:500, filepos: 00018f000
timestamp: 01:03:29:958, filepos: 00018f800
timestamp: 01:03:43:250, filepos: 000190800
timestamp: 01:03:49:291, filepos: 000191800
timestamp: 01:03:54:250, filepos: 000192800
timestamp: 01:04:19:916, filepos: 000193800
timestamp: 01:04:27:916, filepos: 000194800
timestamp: 01:04:35:041, filepos: 000195800
timestamp: 01:04:40:458, filepos: 000196800
timestamp: 01:05:56:916, filepos: 000197000
timestamp: 01:06:05:583, filepos: 000197800
timestamp: 01:06:12:958, filepos: 000198000
timestamp: 01:06:24:708, filepos: 000198800
timestamp: 01:07:00:208, filepos: 000199000
timestamp: 01:07:08:250, filepos: 00019a800
timestamp: 01:07:10:916, filepos: 00019b000
timestamp: 01:07:17:916, filepos: 00019c000
timestamp: 01:07:26:000, filepos: 00019c800
timestamp: 01:07:29:083, filepos: 00019d800
timestamp: 01:07:35:375, filepos: 00019e800
timestamp: 01:07:39:916, filepos: 00019f800
timestamp: 01:07:41:916, filepos: 0001a0000
timestamp: 01:07:47:333, filepos: 0001a1000
timestamp: 01:07:58:125, filepos: 0001a2000
timestamp: 01:08:17:958, filepos: 0001a2800
timestamp: 01:08:23:125, filepos: 0001a3800
timestamp: 01:08:26:458, filepos: 0001a4000
timestamp: 01:08:34:541, filepos: 0001a5000
timestamp: 01:08:37:500, filepos: 0001a6000
timestamp: 01:09:09:208, filepos: 0001a7000
timestamp: 01:09:12:291, filepos: 0001a8000
timestamp: 01:09:15:916, filepos: 0001a9000
timestamp: 01:09:23:291, filepos: 0001aa000
timestamp: 01:09:28:250, filepos: 0001ab000
timestamp: 01:09:33:375, filepos: 0001ac000
timestamp: 01:10:24:916, filepos: 0001ac800
# Vob/Cell ID: 1, 12
timestamp: 01:10:29:916, filepos: 0001ad800
timestamp: 01:10:33:916, filepos: 0001af000
timestamp: 01:10:40:041, filepos: 0001b0000
timestamp: 01:10:50:833, filepos: 0001b1000
timestamp: 01:10:54:041, filepos: 0001b1800
timestamp: 01:10:57:000, filepos: 0001b2800
timestamp: 01:11:00:125, filepos: 0001b3800
timestamp: 01:11:20:791, filepos: 0001b4800
timestamp: 01:11:33:791, filepos: 0001b5800
timestamp: 01:11:39:833, filepos: 0001b6000
timestamp: 01:11:42:958, filepos: 0001b7000
timestamp: 01:11:55:166, filepos: 0001b7800
timestamp: 01:12:35:541, filepos: 0001b8000
timestamp: 01:12:44:583, filepos: 0001b9000
timestamp: 01:12:49:875, filepos: 0001ba000
timestamp: 01:12:55:750, filepos: 0001bb800
timestamp: 01:12:58:583, filepos: 0001bc800
# Vob/Cell ID: 1, 13
timestamp: 01:13:39:666, filepos: 0001be000
timestamp: 01:13:55:416, filepos: 0001bf000
timestamp: 01:14:04:916, filepos: 0001c0800
timestamp: 01:14:07:958, filepos: 0001c1000
timestamp: 01:15:50:583, filepos: 0001c2000
timestamp: 01:16:13:000, filepos: 0001c3000
timestamp: 01:16:46:375, filepos: 0001c4000
timestamp: 01:16:52:250, filepos: 0001c5000
timestamp: 01:17:00:541, filepos: 0001c6000
timestamp: 01:17:04:375, filepos: 0001c7000
timestamp: 01:17:17:083, filepos: 0001c8800
timestamp: 01:17:22:250, filepos: 0001c9800
# Vob/Cell ID: 1, 14
timestamp: 01:20:06:833, filepos: 0001cb000
timestamp: 01:20:31:125, filepos: 0001cb800
timestamp: 01:20:54:541, filepos: 0001cc800
timestamp: 01:20:57:083, filepos: 0001cd800
timestamp: 01:21:01:958, filepos: 0001ce800
timestamp: 01:21:15:416, filepos: 0001cf800
timestamp: 01:21:20:125, filepos: 0001d0800
timestamp: 01:21:24:958, filepos: 0001d1800
timestamp: 01:21:35:083, filepos: 0001d2800
timestamp: 01:21:39:291, filepos: 0001d3000
timestamp: 01:21:49:416, filepos: 0001d4000
timestamp: 01:21:57:958, filepos: 0001d5000
timestamp: 01:22:06:625, filepos: 0001d6000
timestamp: 01:22:17:458, filepos: 0001d7000
timestamp: 01:22:21:250, filepos: 0001d7800
timestamp: 01:22:28:500, filepos: 0001d8800
timestamp: 01:22:32:708, filepos: 0001d9000
timestamp: 01:22:52:541, filepos: 0001da000
timestamp: 01:23:00:916, filepos: 0001db000
timestamp: 01:23:06:166, filepos: 0001db800
timestamp: 01:23:09:750, filepos: 0001dc000
timestamp: 01:24:26:166, filepos: 0001dd000
timestamp: 01:27:02:916, filepos: 0001de000
timestamp: 01:27:19:166, filepos: 0001df000
timestamp: 01:27:24:000, filepos: 0001df800
timestamp: 01:27:36:291, filepos: 0001e1000
timestamp: 01:27:52:208, filepos: 0001e2000
timestamp: 01:28:39:458, filepos: 0001e2800
# Vob/Cell ID: 1, 15
timestamp: 01:31:32:333, filepos: 0001e3800
timestamp: 01:31:54:208, filepos: 0001e4000
timestamp: 01:32:16:875, filepos: 0001e4800
timestamp: 01:32:53:791, filepos: 0001e5800
timestamp: 01:33:04:583, filepos: 0001e6800
timestamp: 01:33:08:958, filepos: 0001e7000
timestamp: 01:33:14:708, filepos: 0001e8000
timestamp: 01:33:19:791, filepos: 0001e9000
timestamp: 01:33:23:250, filepos: 0001ea000
timestamp: 01:33:35:583, filepos: 0001ea800
timestamp: 01:33:38:291, filepos: 0001eb000
timestamp: 01:33:41:750, filepos: 0001eb800
timestamp: 01:33:50:416, filepos: 0001ec800
timestamp: 01:34:04:041, filepos: 0001ed000
timestamp: 01:34:06:791, filepos: 0001ee000
timestamp: 01:34:09:958, filepos: 0001ee800
timestamp: 01:34:45:041, filepos: 0001ef000
timestamp: 01:34:55:416, filepos: 0001f0000
timestamp: 01:35:19:750, filepos: 0001f1000
timestamp: 01:35:23:875, filepos: 0001f2000
timestamp: 01:35:43:875, filepos: 0001f2800
timestamp: 01:35:48:291, filepos: 0001f3800
timestamp: 01:36:50:125, filepos: 0001f4800
timestamp: 01:37:06:875, filepos: 0001f5000
timestamp: 01:37:37:583, filepos: 0001f6000
timestamp: 01:37:45:458, filepos: 0001f6800
timestamp: 01:37:49:833, filepos: 0001f7000
Follow-up...
This is no longer an urgent problem, as I was able to get things to work with a .srt file that also came with the movie. It was just badly out-of-sync, which was why I was trying to get the .idx and .sub files to work. Fortunately, I was able to find a way to get SubSync to adjust the times using the beginning and ending times from the .idx file.
Thanks, and if anyone can find a solution to this problem in his/her spare time, please post it here.
Merry Christmas!
How to extract idx/sub subtitle from dvd source video without vobsub rip?
By cairuitao123 in forum SubtitleReplies: 7Last Post: 20th Apr 2014, 12:31 -
Convert ASS/SSA to Vobsub (idx/sub)
By thepoolhustlerman in forum SubtitleReplies: 2Last Post: 21st Aug 2011, 04:36 -
What do i do with a .idx file ?
By midiw in forum ffmpegX general discussionReplies: 4Last Post: 8th Mar 2011, 14:47 -
BDSup2Sub - A converter from Blu-Ray SUP to DVD SUB/IDX (VobSub)
By devilcoelhodog in forum SubtitleReplies: 0Last Post: 2nd Mar 2009, 20:46 -
How to join the idx/sub languages ripped separatedly into just one idx/sub?
By Talayero in forum SubtitleReplies: 5Last Post: 29th Mar 2008, 08:58
s:ms
