I mean be a complete idiot by setting this up wrong, but here we go. I installed the card no problem. I set up my vcr and I hook it up using A/V. I use the ATI programs to view my tape, the video shows up, but with no sound. Their has to be an answer! So, I think it was the ATI program, so I tried VirtualDub, but still no Audio. I rehook it in ever possible manner, is their any way to fix it? Or is this just another careless mistake by a newbie.
you didn't mention if you had checked your volume controls, the input maybe muted, mine is coming in under the Wave/Direct Sc.
yeah, i tried that inline for the main control, but do i have to do that with something else?
ATI... You said enough. Nice hardware, shitty drivers, as most already have found out. Shame... Such promise.
<hr>
Well vested in the following: Pinnical DC-10+, TMPGEnc, AVI_IO, VirtualDub, Flask, BBMpeg, SmartRipper, DVD2AVI
<hr> -
I did have audio problem, but it got solved when in ATI I clicked VIDEO SOURCE, then in video driver panel clicked CABLE and then after 1 second clicked COMPOSITE. The sound came right through - I am not sure whether I got your problem right, but give it a try. And pl let me know if you have found a better solution to this problem. Thanks.
This has happened to me a couple of times with new installs. It could be that your ATI card is sharing the same IRQ with your sound card. Look in system properties and see if this is the case. If it is you can manually assign IRQ's in the bios or you can try swapping the cards to different slots and see if plug and pray fixes the problem.
Capture problems using ATI TV Wonder HD 750
By SKot in forum Capturing and VCRReplies: 9Last Post: 3rd Jan 2012, 15:34 -
ati 8500dv resource problems
By jwdove in forum Capturing and VCRReplies: 1Last Post: 27th Sep 2009, 12:48 -
Whats in the pipeline?
By 2Tents in forum SVCD2DVD & VOB2MPGReplies: 12Last Post: 7th Jul 2008, 11:39 -
ATI 7500 AIW capture problems
By saoneg in forum Capturing and VCRReplies: 8Last Post: 6th Mar 2008, 05:11 -
Problems with Pal-60 capture using ATI AIW 2006 PCI express Radion X1300
By DB83 in forum Capturing and VCRReplies: 2Last Post: 6th Aug 2007, 16:49
