I have a divx (640x272, 25fps) that i am converting to NTSC Film vcd. I have the framerate and audio good but on the source, the aspect ratio is 2.35:1 but the output is always about 2.5...:1. How can i keep the same aspect ratio. I am using Tmpg and there is no source ratio option of 2.35:1 so i use 1:1 vga. I have tried all settings for the option and have also tried full screen keep aspect ratio 1 and 2.
On another note what are the settings I should use for absolute maximum quality? Speed is not an issue but I want the highest quality possible.
Under the Video Tab, make sure the Aspect Ratio is 4:3 (NTSC). Also, under the Advanced Tab, make sure the Source aspect ratio is 1:1 (VGA) as DivX is always 1:1 (VGA) for the Source aspect ratio.
Hope That Helps!!!
:P
Resolution & Aspect Ratio
By markf78 in forum Video ConversionReplies: 4Last Post: 11th Apr 2011, 15:17 -
Resolution and Aspect ratio
By Mrsash in forum Video ConversionReplies: 4Last Post: 19th Nov 2009, 17:37 -
Resolution vs Aspect Ratio
By triptych in forum Newbie / General discussionsReplies: 17Last Post: 7th Aug 2009, 08:23 -
Aspect Ratio/Resolution Question
By kidcash in forum Newbie / General discussionsReplies: 3Last Post: 4th Nov 2007, 04:43 -
Please explain Aspect Ratio and Resolution
By slmnow in forum Newbie / General discussionsReplies: 8Last Post: 21st Aug 2007, 20:14
