Hey B, I need help on this one. I got my system re-built but AfroPic doesn't work at all. I have 1 VOB and Here is what I am getting:
/Installed Apps/VCD & SVCD Tools/AfroPic 0.3.1r2/AfroPic 0.3.1r2.app/Contents/Resources/shell: bbdmux: command not found
INFO: [mplex] mplex version 2.2.1 ($Date: 2002/04/20 19:08:30 $)
**ERROR: [mplex] Unable to open file video.m2v for reading.
rm: video.m2v: No such file or directory
usage: movtoy4m -w width -h height -F a:b -a a:b movie.mov
example: movtoy4m -w 352 -h 288 -F 25:1 -a 4:3 pal_normal.mov
example: movtoy4m -w 352 -h 240 -F 30000:1001 -a 16:9 ntsc_wide.mov
**ERROR: [mpeg2enc] Could not read YUV4MPEG2 header: system error (failed read/write)!
rm: temp-1.mpg: No such file or directory
**ERROR: [mplex] Unable to open file /Users/mac/Desktop/MOVIE/Output/movie for reading.
rm: movie: No such file or directory
9:30PM up 58 mins, 3 users, load averages: 0.70, 0.53, 0.55
-2 is not a valid mpeg file
rm: /Users/mac/Desktop/MOVIE/Output/movie-1.mpg: No such file or directory
++ WARN: initializing libvcd 0.7.12 [darwin5.2/powerpc]
++ WARN:
++ WARN: this is the UNSTABLE development branch!
++ WARN: use only if you know what you are doing
++ WARN: see http://www.hvrlab.org/~hvr/vcdimager/ for more information
++ WARN:
**ERROR: could not stat() file `split-1.mpg': No such file or directory
++ WARN:
++ WARN:
**ERROR: could not stat() file `split-2.mpg': No such file or directory
rm: split-1.mpg: No such file or directory
rm: split-2.mpg: No such file or directory
thats very weird-- originally i thought it was a problem with the "&" in the name of one of the folders afropic is inside of, but i just ran a test with a folder with that in the name and didnt have your problem... very strange ill see what i can figure out about that.
As below, so above and beyond, I imagine
drawn outside the lines of reason.
Push the envelope. Watch it bend.
Over thinking, over analyzing separates the body from the mind. Withering my intuition leaving all these opportunities behind.
