Okay, I got two movie files. I want to put both on 1 CD. If I do so will the DVD player just go from one file to another or do I have to have each on another CD?
Yes, you can put both on one CD if the files are not too large. The DVD player should play them in order, unless you set up another behavior in the PBC.
Either I'm an idiot or you gave me the wrong site because I found nothing I was looking for :/
That site gives you in depth article and guides on how to author PBC content on your VCDs.
I suggest you read them more closely as I doubt that you could have read the whole thing in 7 minutes.
For a GUI approach, VCDEasy is high recommended.
Regards.Michael Tam
w: Morsels of Evidence -
Also, can you remove that image from your signature please? It is over 90kb in size and some people here still use dial-up.
If you replace it with another image, keep it to the same size restraints as the avatar image (i.e., < 6 kb).
Thanks.
Regards.Michael Tam
Trying to burn two separate videos to the one BD-R disc
By Lysdexic in forum Authoring (Blu-ray)Replies: 5Last Post: 7th May 2012, 20:28 -
trying to burn my videos to dvd
By dwayne00 in forum Newbie / General discussionsReplies: 4Last Post: 24th Sep 2009, 10:21 -
burn speed for videos
By gameroftheuk in forum Newbie / General discussionsReplies: 5Last Post: 19th Aug 2008, 12:51 -
Need to downsize a few videos to burn on DVD
By UmmAddan in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2008, 19:54 -
which is the best dvd to burn videos
By rex2745 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jul 2007, 23:13
