  1. Is there a relation between a capture board and quality of capture ?
    I have a Dv Sony camera and Pinacle 7 capture board.
    Do I need to buy a better capture board to improve quality of captured material?
  2. IMO u doing fine with what u got
  3. Member vhelp's Avatar
    Mar 2001
    New York
    hello.
    give us a little more detail of your process (start to finish)
    some examples:
    * your source
    * quality of
    * how you are bringing it in DV firewire or analog capture card
    * post editing/filtering ie, vdub filters and/or tmpg filters
    * software apps to bring in from DV or analog captures
    * codecs being used, if any
    * encoder
    * encoding process/settings
    * anything else
    so that "any" of us can help ya.
    ok, got carried away.
    -vhelp
  4. Originally Posted by murzik
    I'll note that many of the lower end tv tuner cards have the same BT 848/878 chipset in them. Therefore, I doubt there is much differece in them save the input connectors (S-video, composite, coax, etc.) vhelp gave you some good starting points and I would work that stuff before I upgraded from say a $40 or $50 card to a $80 or $90 card.....
