Going through DVD/SVCD/CD authoring software, I've seen MANY references to disc with capacities of 740mb and even 100min/800mb discs. I'd never heard of these, and a trip to Microcenter comfirmed that they're not a common commodity I'd just never noticed. How are these sizes possible? If they're out there, I want them!
is it just overburn?
When authoring a VCD or SVCD you burn in mode2 and you are able to burn 800MB on an 700mb/80min cd. You can overburn safely to approx 815MB
Thanks for the answer. I actually just found this in another post. I should have read a little more thoroughly I guess!
Also, in order to fit that much data on a disc, does it have to be a BIN/CUE image from a Vcd authoring program, or will just sticking your mpeg in Nero work?
And if you can get 740mb on a 74min disc, and 800mb on an 80min disc, what are these 90 and 99min discs that Nero and DVD2SVCD talk about? After a thourogh sortie at Microcenter, I didn't see a single disc of about 100 different kinds that advertised over 80min. -
Those higher minute discs are not as popular and are not as widely compatible as the 80min discs. To burn VCD in nero you can use the wizard and create a new cd , Video CD. then just drag your mpg file over and it will check the file and then you can hit burn.
Would you consider this latest news ?
Moving to newbie
Longevity of CDs and DVDs? Are my old CDs starting to lose it?
By garybeck in forum DVD & Blu-ray RecordersReplies: 15Last Post: 25th Jan 2013, 14:38 -
remove episode from the middle of 800mb AVI ?
By pribl in forum Newbie / General discussionsReplies: 16Last Post: 10th Nov 2011, 11:26 -
800mb avi; Would want it to go onto a 700mb CD
By mark63534 in forum Newbie / General discussionsReplies: 39Last Post: 28th Feb 2010, 20:31 -
How do I make a 700MB+ video file to a 700MB video file?
By riahc3 in forum Newbie / General discussionsReplies: 26Last Post: 2nd Jul 2009, 21:55 -
Nero works with CDs not with DVDs
By fiiido in forum DVD & Blu-ray WritersReplies: 13Last Post: 23rd May 2008, 04:44
