I have a DVD-Burner using Nero 5.5.9 with a Pioneer 2x burner A04 I believe, (writing this at work). The movie burns fine to the DVD, but when playing the DVD on my standalone APEX AD5131, it starts out fine for about a hour or so, and then just starts freezing, and can't jump thru chapters. The only way of getting out of it is shutting down my DVD player.
What is the better DVD-R media TDK or Ritek?
what program are you using to author the dvd with?
I've had great sucess with Ritek and my pioneer players - 343 and c503.
Perfect playback.
-d -
Freezeing,pausing, and stuttering are almost always media compatibility problems. TDK is the better of the 2 medias but is very expensive compaired to some of the great prices on Ritek G03 disk out there.
Which one did you burn with thats giving you this problem?
Personally I've had great compatibility with the Ritek disk. -
I also use Ritek DVD-R and I'm not having any trouble with them. Are you sure that you have true Ritek media? I know that most Ritek DVD-R's are unbranded so you are never sure what you are getting. I've been purchasing media from www.atdiscount.com for about a year now and have not had any trouble. Never the less, they will guarantee the media. Try them out. I did.
DVD ER
problem with playback of 3D on BD -R media
By spot01 in forum Authoring (Blu-ray)Replies: 1Last Post: 27th Sep 2011, 12:46 -
Occuring Media ProbleM
By Joe94 in forum Software PlayingReplies: 2Last Post: 5th Feb 2011, 07:01 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 22:49 -
*SOLVED* Media problem or workflow problem? (Media problem)
By nosleep in forum Authoring (DVD)Replies: 7Last Post: 2nd Jan 2008, 20:35 -
Media Center Problem
By beric3236 in forum Media Center PC / MediaCentersReplies: 0Last Post: 5th Nov 2007, 11:45
