I have a dat file that i would like to convert to mpeg, i have tried using the VCDGear but once completed when I try to play the mpeg I get an error "No combination of filters could be found to render the stream" however when i play the DAT file it plays fine. Does anyone have any idea what i could do to convert it over?
THanx
"Computers are stupid, but they are capable of being stupid one million times per second"
Well i feel dumb, that worked, thank you very much
"Computers are stupid, but they are capable of being stupid one million times per second" -
Though that just let's you open it with media player without going to Open with... or associating .dat files with media player, it's still not really an .mpg. If you were to try loading it into something like VCDEasy it would probably tell you as much and not let you load it. Try VCDGear again but disable file splitting and fix errors and see if that works or you could try using something like TMPGEnc and doing a simple multiplex using the .dat file as both video and audio source, that should at least give it a proper header.
Yeah, i burned 50 roswell episodes, before i got my dvd burners,
an a05 and a 105 now, i think i might convert them back to mpg
so i can burn each episode to a dvd,not sure though.... -
LOL, that was a quick and dirty fix, but the best way is to use VCDEasy to reverse the process. Select TOOLS, then the MPEG SCAN tab. At the bottom of the screen, simply load your DAT file then click on convert.
VCD Karaoke (MPEG DAT file)- removing the vocals
By tsrusa2002 in forum Video ConversionReplies: 12Last Post: 22nd May 2011, 02:51 -
DAT to MPEG 1
By MI6 in forum Video ConversionReplies: 14Last Post: 8th Feb 2009, 15:01 -
convert VCD.DAT/MPEG to RMVb with dual channel audio
By newbievideohelp in forum Video ConversionReplies: 15Last Post: 6th Nov 2008, 23:42 -
How to corp a dat or mpeg file to mpeg
By onlyrasel in forum VCDEasy GeneralReplies: 1Last Post: 26th Sep 2008, 23:18 -
dat to mpeg - no sound
By goshz in forum Newbie / General discussionsReplies: 9Last Post: 22nd Jun 2007, 04:24
