ok...when u download a MPEG...can u just burn it like it is? to make a vcd? or should u still run it thru tmpgenc?
no warez or crack questions please
edited by BJ_M
You can try to burn it, but it may not be a VCD compliant MPEG file. If you use Nero (and Roxio, I think), the VCD burn routine automatically checks the file to verify it complies and warns you if it doesn't. If it is close, some machines will play it (my Sharp will in some cases). But compatibility is not guaranteed. If it is something completely foreign, you'll definately have to re-encode.
Use a program like "iFilmEdit" to convert the Mpeg to VCD (Mpeg1) format.
Regards. -
maginniss, usually when I download an MPEG, I re-convert it to another MPEG so I know it is fully compliant. Usually MPEG's that you download are probably non-compliant.
Hope The Suggestion Helps You!!!
:P
You can try, and if the automatic checking does not detect a problem you're in good shape. But I'd guess the vast majority of mpg's you download will not be compliant. And when you re-encode the resulting quality will look less than stellar on a large TV screen.
You can try Tmpgenc to remux to VCD-mpeg1 (not re-encode). Use Tmpgenc's Mpeg tools, it worked for me in the past. Also, because of errors, I had to use some of the mpeg correction utilities first. You'll find them in the tools section fo this site.
converting MPEG-TS to MPEG-PS (from a Noontec V9)
By ninereeds in forum Video ConversionReplies: 2Last Post: 28th Jul 2010, 11:17 -
Quicktime parse error converting mpeg-1 muxed to DV or mpeg 4
By jglass in forum Newbie / General discussionsReplies: 0Last Post: 15th Jun 2008, 21:51 -
Problem converting audio of VCD MPEG-1 to author DVDs
By Greycat in forum Video ConversionReplies: 6Last Post: 16th Jan 2008, 17:28 -
This is a minefield! (converting mpeg to mpeg for DVD)
By uth in forum LinuxReplies: 29Last Post: 18th Nov 2007, 16:04 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54
