I am capturing VHS to AVI. Do capture interlaced or de-interlaced. Same question with Hi8 tapes.
Is there something on this website that explains interlaced and non-interlaced, and when to use each?
TIA,
-Tom
If you want to watch the video on both pc and t.v. then you have to de-interlace. If just for t.v. only you can leave it interlaced.
Generally you capture in interlaced. What you do with it form there is anotehr issue. What the final product is going to be determines if you have/need to de-interlace. DivX/XviD yes, MPEG-1/2 the encoder will deal with it.
To Be, Or, Not To Be, That, Is The Gazorgan Plan
interlace help
By nymph4444 in forum Newbie / General discussionsReplies: 339Last Post: 17th Jun 2011, 02:33 -
Question about HD to SD and interlace>progressive>interlace
By ayim in forum Video ConversionReplies: 4Last Post: 10th Dec 2009, 12:21 -
Interlace Question (I think....)
By pezpunk in forum Newbie / General discussionsReplies: 4Last Post: 15th May 2008, 10:20 -
VirtualDub De-interlace
By Lee82 in forum EditingReplies: 16Last Post: 25th Feb 2008, 18:57 -
Interlace confusion
By Bagshot in forum Capturing and VCRReplies: 7Last Post: 16th Feb 2008, 08:46
