I have an avi file, here are the details:
Average data rate: 24.00
sample rate: 48 khz
audio channels : 2
frame width : 608 pixels
frame height: 256 pixels
frame rate : 23.976 frames/sec
compression : XVID
I tried using tmpenc to encode to dvd ntsc mpeg2, but the video was slightly stretched VERTICALLY. Just a bit. The movie seems to be 16:9, so what settings should I use in TMPEnc?
Here is what I tried:
from the "video" options:
Frame size: 608 x 256
Aspect ratio : 1:1 VGA
I chose 23.976 frames/sec and the 3:2 pulldown thing.
From "Advanced" I had:
Source aspect ratio: 1:1VGA
Full screen(keep aspect ratio 2)
What settings should I have used?
Thanks for any help. I want to preserve the 16:9 aspect ratio
p.s. I would prefer the mpeg2 to be in PAL, can I do this, and what are the settings?
[/b]
Under the Video Tab next to Aspect ratio, set it to 4:3 or 16:9 depending on your T.V, and under the Advanced Tab next to Source aspect ratio, set it to 1:1 (VGA) as DivX is always 1:1 (VGA) for the Source aspect ratio. You can do whatever you want to the other Tabs and settings. 8)
Hope That Helps!!!:P
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 07:45 -
ABBA inducted in Rock & Roll Hall of Fame
By deadrats in forum Off topicReplies: 3Last Post: 20th Dec 2009, 15:52 -
How to Put Specifical Signs Using Credit Roll, from Sony Vegas?
By devilcoelhodog in forum EditingReplies: 9Last Post: 9th Nov 2009, 15:26 -
Roll back of 5 secs
By GeordieDave in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 1st Sep 2008, 11:40 -
Menu Problems - No Roll Overs - Where are I in the menu?
By dunncha in forum SVCD2DVD & VOB2MPGReplies: 81Last Post: 10th Nov 2007, 07:40
