I downloaded a movie. It's 2 Divx Avi files but when i want to burn them as a SVCD they are to big.
Is there a possibility to create from the 2 Avi files 3 SVCD's ????
Merge them together in VDUB. Then follow the standard guide for DivX--> SVCD.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
To be a bit more specific:
Open the first AVI in VirtualDub
Set Audio to Direct Stream Copy
Set Video to Direct Stream Copy
From the File menu:
Select FILE | Append AVI Segement
Select your second avi.
Select FILE | SAVE AVI, and give it a new name.Impossible to see the future is. The Dark Side clouds everything... -
Great. Thanks for the help.
No i have 1 Avi file. But How can i burn them on 3 SVCD's ?????? -
Easy.
Split your avi/xviD file into 3 parts. Even of them should be NOT longer than approx. 44 mins to fit on a 700mb SVCD after re-coding!
Use VDub and search for a good point - you must use a Keyframe as startpoint for every of the 3 files to get correct splitted files.
If you have 3 target files I would recommend then encoding to SVCD with TMPGEnc and a SVCD template (various are delivered with the program).
Depending on your encode method (VBR VS CBR), time is not a strict rule of thumb either, but it is a good place to start. 40 minutes on a CBR encode is good. 45-50 minutes on a multipass VBR encode is also good.
convert compressed avi files to mpeg without increase in file size?
By jasoothai in forum Authoring (VCD/SVCD)Replies: 7Last Post: 2nd Nov 2011, 06:29 -
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 03:07 -
convert avi+srt files to avi with embedded subtitles
By flannob in forum Newbie / General discussionsReplies: 0Last Post: 30th Sep 2010, 07:35 -
Append the same AVI file on 70 different AVI files?
By Speed Demon in forum EditingReplies: 3Last Post: 15th Sep 2007, 05:55 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 13:49
