Hi all,
Has anyone discovered how to export to DV using TmpGenc? Right now I am exporting to a series of JPG stills, then bringing them into After Effects.
If there was a quicker way, I would love to hear it. Perhaps there's another app I could be using?
Thanks for your help,
Robotkid
www.robotkid.com
File-> output to file-> avi file-> video setting determines the codec (dv or otherwise)
Yep, that's what have been trying, and I can only see:
No Recompression
Do I need to point TmpGenc at some codecs or something?
Thanks!!!!
-J -
do not understand the origial question. wha tdo you mean "exporting of series of JPG stills". do you mean " converting JPG still to DV"? If that is correct, try vegas video.
Sorry,
I am exporting the movie as a "still sequence," which is basically a huge folder full of .jpg frames. I can then import these back into After Effects using "import still sequence" and it turns it back into a full movie.
What i am trying to do is simply convert footage in TMPGenc to DV footage. I would also like to try converting to DV footage using DVD to AVI.
(I'm trying to re-edit footage given to me from DVD, not rip off commercial DVD movies.)
Thanks again for any assistance!
-Robotkid -
It sounds like you are making a simple thing more complicated. Let me make it short: you are trying to convert a MPEG2 DVD file into a DV file then edit it. Correct?
was waiting for your response. anyway, if you are trying to do what i assumed, Vegas video is the easiest way to go. Just open any MPEG file and render it as DV(AVI) format. You need MPEG plug-in though.
Wrong Codec ??? (for DTS to AC3 conversion) Please help!
By KushSmoka420 in forum AudioReplies: 4Last Post: 29th Dec 2011, 07:50 -
Need Help on XviD4PSP (Conversion of MKV to AVI, subtitles SPU codec)
By gallen16 in forum Video ConversionReplies: 3Last Post: 10th Oct 2010, 10:44 -
Meteor Videos / Conversion-Codec Issues
By mikesastro in forum Video ConversionReplies: 7Last Post: 25th Sep 2009, 18:34 -
Xbox 360 Codec Problem (Conversion Suggestions..)
By ninny jams in forum Video ConversionReplies: 6Last Post: 1st Aug 2009, 11:09 -
Best container & codec for FLV conversion to DVD
By Dsypher in forum Video ConversionReplies: 12Last Post: 21st Aug 2007, 14:53
