  1. Can anyone tell me why i keep getting errors every time i try to convert some aviīs,the error is especially in "ntdll.dll" and a out of source range error. I use Win XP corp. and have had no problems before,sometimes it helps uninstalling TMPGenc,and reinstall,but not always..
  2. search for ntdll.dll, it should be in c:\windows\system32. copy it in to the TMPEGenc folder. you should be fine
  3. nope,didnīt work i get a "write error occured at adress 77F52109 of module ntdll.dll with 00000000" and it is the same error as before i copied the ntdll.dll
