If I ripped the Vts_01_0 DVD menu and mpeg'd it, could I make animated menus with full motion and sound just like on my DVD that actually have the links line up with the corresponding background mpeg? I'm not talking about using their thumbnail structure, I'm talking about looking and sounding just like a DVD menu. I would guess you would need to make images in a photopaint program by grabbing tiffs or bmps from the mpeg with some program that does that, then manually cutting the background away from the link portions and converting the resulting image to the right aspect ratio. I may be talking fantasy here...because TSCV's menu options give me a bit of a learning curve. Has anyone found a way to make these types of menus that I'm talking about in VCD format using only the VCD file structure and mpg's, and can it be done in TSCV? All advice on this is appreciated, thank you!
Results 1 to 1 of 1
DVD Lab Pro 1.6: Links in menus get blue under fresh Windows installation
By Paker in forum Authoring (DVD)Replies: 4Last Post: 2nd Jun 2011, 13:54 -
Full motion menu creation software with templates?
By TVJunkieLI in forum Authoring (DVD)Replies: 2Last Post: 7th Apr 2011, 09:54 -
Final Cut Express 3 Audio red-lined
By Davideo2 in forum EditingReplies: 3Last Post: 18th Feb 2011, 21:45 -
Full DVD with menus to MKV
By Trigve in forum DVD RippingReplies: 2Last Post: 28th Aug 2008, 08:32 -
Delayed Links, Motion Menu and DVD Lab Pro 2
By christopheramos in forum Authoring (DVD)Replies: 14Last Post: 30th Apr 2008, 02:33
