I'm trying to convert an AVI to VCD and I am having a hard time extracting the sound. I tried to go into virtualdub and switch to full processing mode, but everytime I do that it gives me an error message when I try to make the wav.
Anyone have any suggestions?
Results 1 to 9 of 9
What is the error meessage.
Its a lot easier to find a solution if you know what the problem is! -
I have the same problem when I try to convert certain movies, such as blade II or Harry Potter 1. I follow the guide that is on this website but when I try to save the WAV in virtual dub i get
"The requested audio compression is not compatible with the input format. Check that the sampling rate and channel count of the input match those of the requested format."
I also try skipping virtual dub and using the divx file for the audio source and it says " 'harry potter cd1.avi' could not be opened or is not supported". The file is directly on my hdd. Im thinking its encoded differently or I need a codec pack. If someone has coverted these movies to vcd please tell me how you did it / what codec's / versions of virtual dub/ tmpenc your using. Thanks guys!work sucks :) -
Alright that helped alot, and I am missing an Audio Codec, but I can't seem to find it to download, or what I do get downloaded doesn't help at all.
Gspot shows that the audio codec is '"mpeglayer3 (mp3) (0x0055) ISO/MPEG", I have downloaded a program called l3codecp.exe, but gspot still says I'm missing it?\
What am I missing? -
Alright, now that I have the correct codec, I got rid of that error message, but now when I got to create the wave, it says
Error initializing audio stream decompression: The requested conversion is not possible. Check to make sure you have the required codec.
Any thoughts on what could be causing this? -
In virtualdub check you have the following settings before trying to save the wav file.
Audio->compression Should be set to No Compression (PCM)
Audio->conversion should be set to 44100hz Or No change if the audio is already 44100Hz. -
How do you install the driver now? I can't find the Windows DDK anywhere...
rmvb to avi, sound syncing problems, any tips or tricks
By dudeboy in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 08:19 -
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 15:34 -
Sound problems
By zewzeq in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 20th Nov 2007, 06:36 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
AVI - sound with VLC , no sound Toast burned
By BattyRoy in forum MacReplies: 15Last Post: 27th Jul 2007, 20:21
