  1. Hi all!!
    Please, I must finish a DVD in a few hours but I havent discovered how to do a AUTORUN DVD. And one with NO menu. just insert and play.
    I'm using DVDit PE for authoring.
    Thanks guys!!!
    Mac
  2. Just make your movie the 1st play item.
  3. Thanks bugster! But I'm a stupid newbie...How do I do this with DVDit? It needs a menu with buttons to author, doesnt it?
  4. I got it!!! easy.. thanks all
  5. If you are using the version I am familiar with, you have a main window which represents the TV and a section to the right where you can see your buttons, backgrounds or video/audio assets depending on which button is selected. You must have your video in one file for this to work. Select the video assets option and simply drag the single video to the square labelled forst play. You can then build your DVD either direct to your burner or to a folder on your HD for burning later.
    Hope this helps.
