Can anyone tell me if I can frameserve an XVID avi to get rid of the audio vbr problems. When I play the goldmember xvid its in perfect synch.
I am having problems using tmpgenc (any versions) as it does not appear to want to convert it, despite having altered the settings as shown in vcd guide for xvid's.
I have successfully converted a film using DVD2SVCD using CCE, but the latter part of the audio was out of synch / missing! I am tearing my hair out with this one, so I thought I could possibly separate the Video and Audio streams but am unable to find out how to rejoin in such a way that I can use TMPGenc.
I have the Xvid codecs and have Divx 4 and 5. If its Xvid it would not need Divx 3.11 would it? CCE converts files into cue/bin files that have no sound so this has stumped me. I have even tried Ulead movie but it won't recognise file! Any programs I can use that will allow me just to put AVI in at one end and get an MPEG 1/2 at the other?
any helps people??????
To seperate the audio from the video to make it NOT VBR and recombine with the avi I would do this.Originally Posted by tompearson
1st, open the avi in goldwave (www.goldwave.com) and save out the audio as uncompressed PCM (convert to 44.1khz or 48Khz too, if required). You will get a movie.wav file. Close Goldwave.
Start virtualdub. Open your avi file. Set Video-> full processing, Audio->wav audio and select your movie.wav created with goldwave earlier. Now select file-> save as avi, and give it a new filename. You will now have your movie with uncompressed PCM audio and it should be in synch. Use this as the source to encode to mpeg.
MPEG-TS AVC to regular DivX/XviD (.avi)?
By svebee in forum Video ConversionReplies: 2Last Post: 4th Apr 2010, 06:32 -
Converting from xvid avi to mpeg-2
By busbee2 in forum Video ConversionReplies: 5Last Post: 13th Dec 2009, 00:44 -
Convert avi in xvid to mpeg with subtitle
By mrweisslee in forum Newbie / General discussionsReplies: 2Last Post: 16th Jun 2009, 03:46 -
Is there any equivalent of MyFlix-XE for AVI (divx/xvid/mpeg-4) ???
By flobie11 in forum EditingReplies: 3Last Post: 2nd Feb 2008, 06:12 -
h.264/MPEG-4 to 2-pass XviD (.avi)
By lalala in forum Video ConversionReplies: 4Last Post: 9th Sep 2007, 21:19
