hi friends ;
iam a new in this forum and need help protect my video cd against copying ?
thanks for your help...
waiting for reply..
Mano...
Sure, just don't allow anyone to have physical custody of your CD and they won't be able to copy it. There isn't a copy protection scheme that is completely crack-proof.Originally Posted by cccf25As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
As mentioned in the FAQ, do a FORUM SEARCH. There are several methods, none unbreakable, some with compatibility issues.
Realistically, there is no real way of doing this that is foolproof. I'm sure other people with reply this this post, but my recommendation is that you simply create a still screen that stays on for 10 seconds that says "STOLEN FROM _YOUR NAME_" in big text.
Alternatively, you can be really tricky and do something like this: http://www.michaeltam.com/combination_lock.html but you will need to know how to use VCDEasy and ideally, manual authoring of XML to get it working well.
Regards.Michael Tam
w: Morsels of Evidence -
Can't be done, there is no way. Never found a CD I couldn't copy. Even the ones that check to see if the disk is a CDR! Unless you write your own codec, and don't give it to anyone.
Product for Putting a Head on an Animated Body?
By shira in forum Newbie / General discussionsReplies: 4Last Post: 2nd Jan 2011, 18:10 -
ps3 and Body of Lies blu ray
By rubberman in forum DVD & Blu-ray PlayersReplies: 1Last Post: 16th Mar 2009, 13:10 -
Body Glove Case ruining DVDs?
By jwnulife in forum MediaReplies: 6Last Post: 10th Feb 2008, 20:21 -
Any body know to delte the ACrros using A MacOS X?.
By vriosm in forum MacReplies: 2Last Post: 8th Nov 2007, 08:55 -
Any body interested in letting me put your videos on my site
By goheadtry in forum Newbie / General discussionsReplies: 0Last Post: 3rd Sep 2007, 15:03
