need help plz, i got a bush 2024, on the strength of i found a multiregion hack on another site. Turns out the hack dont work. Am URGENTLY needing this hack as it is a xmas present, though this site hasnt got one registered yet. If anyone knows of the hack , please inform me. TIA
ok looks like i aint gonna get one , anyone suggest another way to get this machine to go multi region plz ?
google strikes again !!
Multi-Region Hacks for Bush DVD-2024
Quick Overview
The hack listed below is non-destructive, and will not invalidate your players warranty. To perform the correct sequence of steps you will only need access to your players front panel and its remote control. Always make sure that the drive tray is empty before following the procedure listed below.
Whilst DVD Reviewer has made every effort to ensure that the information contained inside these pages is both accurate and up-to-date, we take NO responsibility and accept no liability for any damage caused from applying these hacks as laid down on these pages. Use them at your own risk!
How to convert your Bush DVD-2024 player into a multi-region compatible machine
To convert this player to Multi-Region
1. Press the Open button on your remote control
2. Using your remote control, press the buttons 2, 8, 1 and 2, in order, one at a time
3. Press the Close button on your remote control
To playback VCD and SVCD discs on this player
1. Insert the VCD/SVCD disc into the drive tray and close it
2. Using your remote control, press the Goto button repeatedly until the menu says VCD at the top of the screen -
bah, many thnx for your efforts, but that was the hack i tried.
Doesnt work, its that site that made me buy the machine. Thought it could of been me ,but as this site hasnt got it , then i guess it must be a dodgy hack. Weired thing is, the machine plays svcd/vcd straight from the box ?? Is there some type of chip or summing that will make it play multi region. Thanx again for your effort. -
Case closed , i never had the scart in
though my mustek plays ok ,with the normal cables in, this one dont , needs to be a scart. Thnx anyway
help my bush-tv/dvd that is
By villavillain in forum Newbie / General discussionsReplies: 6Last Post: 24th Nov 2010, 18:43 -
Hack for Bush DVD2041 ?!?
By emi in forum DVD & Blu-ray PlayersReplies: 1Last Post: 9th Jul 2010, 08:30 -
Bush DVD 2053
By wraeththu in forum DVD & Blu-ray PlayersReplies: 3Last Post: 21st Feb 2009, 03:41 -
Bush DVR3003XI
By allycat in forum DVD & Blu-ray RecordersReplies: 0Last Post: 4th Jan 2008, 11:41 -
Bush DVD2042XI
By feltos in forum DVD & Blu-ray PlayersReplies: 1Last Post: 14th Nov 2007, 11:25
