  1. Hey guys,
    I have a new Pioneer A05, with Nero 5.5.17 and when I make a DVD, it skips and stops in my Pioneer 343. Now this ONLY happens when I fast forward or back. If I load the disk and do nothing, it will play from start to finish fine. Im not sure about pausing or something, but I would assume it would produce the same result. Basicly playing for a bit, then studdering then a full freeze frame.
    Is this a problem with Nero? Media? Or DVD Player?
    Thanks,
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    343 plays ok here ... though every 343 i tried , after about 6 months to a year has a problem reading svcd or vcd cd-r's .. you have to pop them in and out a few times ..
  3. What authoring software are you using? How did you burn the DVDs?
    Jul 2002
    Just some ideas !!!
    Try and burn at the slowest speed
    Try NERO 5582 , is very stable. 5590 gives me all sorts of problems...numerous coasters etc
    Good Luck
    I read somewhere that video burning can be `distorted` if you burn at high speeds, even though you are meant to be able to
    Calibra
  5. ok what media are U using as my mates ao5 does the same... cheaper bulkpaq dvdr's purple tops work fine but things like riteks & ice also some prodisk dvdr's dont work & will give U this error, the disks are probably fine but they dont write properly....
    get a sampler pack from bigpockets & U will be able to test the media to find a one that works 4 U.
    Kev!
  6. Thanks guys. Actualy the media I'm using is the Pioneer disks which came with the DVD Burner. Go figure?
    About the problem, I wrote a better detailed discription in another thread so that people can better understand if its the DVD player, Authoring method, or Burning software which is at fault.
    Media could be a problem, however I feel skeptical that packed in DVD-R/Ws by pioneer would fail on a pioneer DVD Burner and DVD Player.
