Hi,
I am trying to fit Princess Mononoke onto 1 vcd. It is 135 min long and I am encoding with the kvcd LBR template. It is supposed to fit up to 180 min on one vcd, but smallest file I have been able to produce is 1.3G. Help me!
Results 1 to 30 of 39
Originally Posted by NEO14
-kwagKVCD.Net - Advanced Video Conversion
http://www.kvcd.net -
Nearly two and half hours on one CD?
I think 90minutes of video is pushing it.
You would need to use these numbers or even lower.
Use a 2pass VBR with an average settings of 700 kbits/sec video bitrate.
Use 128 kbits/sec for the audio
Motion search: high
The result will still be pretty crappy. -
Originally Posted by tonyp12
Bear in mind that we're not just talking lowering the bitrate here. These kinds of results are obtained through custom quantization matrices, finely tuned GOP structures, targeted preprocessing, an Avisynth filter designed specifically for increasing the quality of low-bitrate encodes, custom-written software for accurately predicting encoded file sizes, and above all an enormous amount of testing and tweaking by individuals dedicated to pushing every boundary of the MPEG-1 specification.
Don't knock it 'til you try it.
Regards,
SansGrip -
DVD-player-owning viewers thought they were watching a DVD.
On my 56" HDTV Toshiba, anything but true DVD and I can
see the difference.
P.S at a low bitrates going 352x480 (CVD) is better than 704x480 -
I think most of us are aware the results may not be all that great. I have not tested that template, either. However, in defense of Kwag on his website, he does state "...for portable players and small TV's" so, he does let people know that quality may be sacrificed.
Originally Posted by hwoodwar
I have used Kwag's templates in the past - even got 2hrs 25 mins on a CD-R disc. The quality was pretty poor and it is not very compatible, but it is possible.
Now, I've gone the other way and am only putting about 30 mins of MPEG2 onto a CD-R ... in preparation for a move to DVDR in the next few months. For me, quality and compatibility count for everything! -
Here's a 704x480 sample that is the COMPLETE "Red Planet" movie in a single CD-R using KVCDx2 704x480 PLUS: http://www.kvcd.net/clip3.m1v
Another clip: http://www.kvcd.net/rclip2.m1v
And here's a KVCD LBR 352x240 sample from "The Green Mile" using our new parameters, methods, and findings. This is what the COMPLETE 180 minute movie looks like in ONE CD-R: http://www.kvcd.net/test.m1v
Maybe that makes you change your mind
Originally Posted by energy80s
Read all the new stuff here: http://www.kvcd.net/forum/viewforum.php?f=9 , here: http://www.kvcd.net/forum/viewtopic.php?t=1969
Be prepared for advanced topics and a very long read
For those of use who dont have $8000 HD
Philips 46" widescreen progressive scan HDTV for $1100
if you value the DVD player and the 5.1 sound system at $300
Regards,
SansGrip -
However, in defense of Kwag on his website, he does state "...for portable players and small TV's" so, he does let people know that quality may be sacrificed. -
$8000... $1100
same thing
$1100 over the 5year (minimum) lifespan of the TV
comes only to 60cents a day. -
Originally Posted by SansGrip
) which used another GOP. This is a totally new ball game
I just finished encoding Unbreakable with kvcd LBR with CQ 10. The file is still 1GIG!! What am I doing wrong!! Can someone give me some settings to try? Thanx.
Regards,
SansGrip -
Originally Posted by kwag
i do have to admit, the red planet ones looked pretty good, considering it's 1 CD-R. BUT, the fuzziness and blockiness is still noticeable. using at least 2 CD-Rs would remove most of those problems. however, it is a pretty short movie (106 min.) and 2.35:1 aspect ratio (or something like that). btw, did you remove any pixels from the top and bottom of the movie. i did a comparison to my rip of the movie from awhile back and it looks like your samples were a little bit squished
however, the green mile clip looked HORRIBLE, considering the clips were of slow scenes with basically no action (unlike red planet). i think there should be a limit on how much you can fit on 1 CD-R w/ your templates and also depends on the aspect ratio of the movie... (i.e. full screen vs. widescreen, etc..) green mile was pretty close to full screen and prolly needs more bitrate with it.
btw...was there supposed to be sound? -
Originally Posted by poopyhead
. The "Red Planet" was encoded at 704x480 and "The Green Mile" was encoded at 352x240. If you look carefully at the "Mile" sample, it looks no better than a VCD, but not worse either!. And that's what went into a complete CD. Just like that. I compared that sample to my original commercial "The Matrix" VCD, and they look basically the same. Actually I can see more macroblocks on "The Matrix" VCD. As for "Red Planet", no I didn't cut anything from the movie. You're probably seeing the 2 overscan block resize. In your monitor, it will look smaller, but on your TV, it will be streched to the edges. Normally, your TV would cut off about 16 lines on each side, that you would never see. This way, we encode to (size-overscan blocks) and your TV will expand to the edges. The benefit is higher bitrate/pixel ratio.
Edit:Forgot to add that the samples are soundless.
also, i'm not sure ANY 2 hr movie...full screen movies cover the entire screen, so each pixel will get even less bitrate....dunno how you can still fit on 1 CD-R without making the quality much worse. -
Kwag seems to really belive in his templetes.
And I admire his energy to defend his "product".
But in 6 Months when DVD burners will cost $99-$149*
Who will use CDR?
The online movie trading scene will use Divx.
And if their dvd player does not play divx,
they will re-encode at 6000 kbits/sec CBR
Motion Search: estimate(fast)
for a quick re-encode that will look as
good as the divx source did.
* estimate, the lowest priced DVD-R burner seen so far: $169 -
i have a DVD burner
and i still burn VCDs
CDRs are and always will be cheaper then DVD(-+)Rs
so if i am happy with the quality of a movie on one CD. Why would i burn the movie onto a DVD, which would cost more, and take more time (burning that is) -
Originally Posted by johneboy
And if I'm not happy with the quality for one CD, I'll use 2 CD's and accomplish the same quality as a DVD. And when the time really comes to start using DVD-Rs because of prices on DVD-R media are ridiculous, then I'll use KDVD Full D-1 and put 4+ hours on a DVD-R or 8+ hours using KDVD Half D-1, while everyone else puts 2 hours with regular encoding techniques 8)
$1.60 for 2.4X DVD+R that will burn 4.37GB in under 20 minutes.
If the movie is worth keeping, spend it.
A few DVD+RW if you want to keep it just for awhile.
In 6months DVD+R disc will probably be $1 each. -
Who will use CDR?
Of course, one day we'll all be burning DVD-Rs and VCDs will be but a memory. Until then I'm going to keep pushing the envelope to see just what MPEG-1 can achieve using today's hardware. And when I do get a DVD burner, I'll see just how many movies I can fit on a single disc...
Perhaps what some people (not necessarily yourself) don't realize is that this is as much a game, a sport, a challenge, as it is anything else. I don't really have anything to prove by doing this. It doesn't give me bragging rights, nor make me superior to those who'd rather jack up the bitrate for the highest possible quality.
For sure, if I was encoding something very precious to me (such as my honeymoon, er, wedding video) I wouldn't use one of these templates. And you're right: these encodes are still no substitute for a DVD when you consider the 5.1 sound and all the extras.
I and many other people do this for the intellectual challenge and the buzz we get from doing what so many claim is "impossible". That's all. It's really not worth everyone getting so worked up about.
The online movie trading scene will use Divx..
Regards,
SansGrip -
How to upload more than 10 min on YOUTUBE
By 3thman in forum Video Streaming DownloadingReplies: 5Last Post: 6th Mar 2010, 14:59 -
Why does it only convert 15 min. worth?
By woodcliff in forum ffmpegX general discussionReplies: 1Last Post: 12th Dec 2009, 20:11 -
Last few min of AVI being cropped out
By Mr_Del in forum Video ConversionReplies: 1Last Post: 15th Mar 2009, 08:59 -
Problem conver with TMPGEnc Plus-2.54.37.135
By sleung in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 14:53 -
tmpgenc 2.54.37.135 problem on core 2
By softech in forum Video ConversionReplies: 1Last Post: 10th Aug 2007, 11:52
