  1. I have a movie that i want to convert into vcd. I do it the same way as usual:
    -- Virtual Dub - Extract the WAV file
    -- TMPGENC - convert
    when i was cleaning up my hd and remove the unneccessasry files i accidentally del some kind of codec and now every time when i try to use virtual dub to extract eh WAV files this error message occurs:
    "ACM failed to suggest audio depression format" and
    "AviOutputWAV: The handle is invalid"
    Want am i doing wrong. Can anybody help!!!
  2. i use gspot2 and look which codec is missing and i found this....
    mpeglayer3 (mp3) (0x0055) ISO/MPEG
    anybody know where can i download this codec...
  3. k i fix everthing already
    damn i should read other people's post instead other then open the same post over and over again.
    sorry for trouble and thx for the help which is found in other posts
