I have a standard video card right now. And I would very much like to upgrade it. I want a Video Capture card AND a video card with TV-OUT with the RCA jacks.
Okay my question is this:
Is there a card that has both video capture and video out with the rca jacks? If not, is it wise to have a capture card hooked up to a computer that also has a video out card?
The ATI All In Wonder of all varities have Video In and out. I use an ATI Rage Fury Pro that has video in and out but no tuner since I don't need one to record off of sattelite TV.
I believe there are also some GeForce cards that have Video in and out, but I can't address them since I have never used one.
You also have the option of using a capture card seperate from a video card which should work fine.
Alright thanks a lot! I will try to find a fairly in expensive ATI All in Wonder card, but yet a reliable one.
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 11:42 -
Hi8 capture- Suggestions for Harddrives and Capture Cards?
By CMP1223 in forum Capturing and VCRReplies: 7Last Post: 10th Jun 2011, 23:05 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 18:05 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 19:42
