First I do have some basic How To knowledge! The DVD "Stuart Little 2" Well I ran through this guide
"DVD9 to 1 DVDr with only 2 programs, NO reencoding !" by
Anyhow I went thru the guide and it ALL went great! When I put the DVD in my DVD player it started playing the intro with the lady holding the torch and then it went into the begining of the movie (Looks Great so far) then it started over again playing the intro with the lady holding the torch and then you hear Stuart Little say to press the "Select" Button to view features! If you just let it play it then go on into the movie!
MY QUESTION: how do I get rid of the first intro? Maybe I should be a little more to the POINT! How can I TELL, where this first Intro is and then how to delete? Is there some type of program that I can use to Physically view and then say Delete a scene(s) I don't want? If I didn't want track #2 on this dvd how can I find it to delete it? Just making sure I'm explaining myself correctly!! THANK EVERYONE!![]()
What you are looking for is called IFOEdit. It strips out VOB IDs like the intros, FBI warning, etc. and corrects all the .ifo files accordingly. It can do some much more, including stripping those troublesome multi-angles. AWESOME TOOL, Doom9.org has some good guides as well as http://www.IFOEdit.com. Expect to spend quite a few days to understand this program and the tools used with it (IFOUpdate, VOBRator, etc.).
ok with this method you are using will i still be able to re-encode the movie to fit on a DVD-R or is that for splitting on two disk,will it still be DVD compliant?
oly19: read my guides (encoding.n3.net) or the ones at doom9.org
http://encoding.n3.net <-- for all your DVD and CD backup needs! -
Stuart Little 2 movie only will easily fit on 1 disc with no stripping or reincoding. I chose to remove the fullscreen version and trailers maintaing everything else using this method so generously provided by 2COOL found here:
http://forum.doom9.org/showthread.php?s=&threadid=40932 -
SL2 was the 1st title I Burned following the guides I did'nt even realized I stripped out the Fullscreen version. It came out great I removed the subs and the foriegn language tracks I left only the DD5.1 and the 2.0 tracks. THe only thing I would like to retained was the intro menu. Is this possible I don't think so in Ifoedit.
You can keep the DVD exactly like the original, menus and all. You only have to remove is one version of the movie, the aspect ratio selection menu, and the trailers to fit it on one disc. I followed 2COOL's instructions to the letter and it worked perfectly. It does assume a basic understanding of IFOEdit but worth it. You can read about it here:
http://forum.doom9.org/showthread.php?s=&postid=229705#post229705
Complex problem, extra some chpts from 2 dvd and combine into 1 dvd + menu
By Shihtzu88 in forum Authoring (DVD)Replies: 1Last Post: 23rd May 2009, 09:09 -
sub-menu problem in DVD Architect Pro 4.5
By younso in forum Authoring (DVD)Replies: 9Last Post: 3rd Jul 2008, 17:51 -
TPMGEnc DVD Author 3 Menu Problem
By ^D3vIL^ in forum Newbie / General discussionsReplies: 4Last Post: 16th Sep 2007, 18:43 -
Problem rendering DVD and menu with Ulead DVD Movie Factory 6
By Jeff_NJ in forum Authoring (DVD)Replies: 2Last Post: 12th Sep 2007, 04:26 -
DVD Menu Flash problem
By jcubz in forum Newbie / General discussionsReplies: 10Last Post: 15th May 2007, 23:26
