I am using Premire 6.5 to capture DV video via firewire card, it works perfectly in first half hour with 0 frame drop. However it stoped after 40 minutes continueous capturing, the video preview came to a still , but the camcorder does not, it still plays video back in its LCD.
I use a seperate 80G hard disk to store the captured avi file, it has NTFS file system and runs in UDMA-5 mode and has more than 30G left after the capturing stoped. I did turn off screensaver and other uncessary program and did not start any other program after capturing, does anybody know what is going on with Premire, is it too tired??![]()
this will happen when there is a audio glitch -- like a mic being dropped or plugged in or spike ..
its a known bug ... it works slightly better in 6.5 (some say not) ..
try to capture with DVIO or Scenalyzer or something else ... -
if he was capturing on a 80gig drive and there was 30gig left and since it was a ntfs drive -- thats not a problem ..Originally Posted by rsuave5
BJ_M is right, NTFS file system does not have file size limit, and I already captured more than 20 gig for the first half hour. If I try to re-capture after the stop, Premier will start capture again, but it only works for several minutes and then stop again. However, if I re-start the computer, Premier will work for another half hour and come to a stop, again!!!
I use Premiere6.5 to capture.
I've got a P4 2.0Ghz with 1GB of ram.
I capture via an Adaptec4300 firewire adapter to an 80GB EIDE drive.
I have captured 60 minute DV tapes at least a dozen times.
Never lost even 1 frame.
Not sure this helps, but I just wanted to let you know that it does work for at least one person....and is not a bug or something.
ffmpeg.exe has stoped working
By downer in forum SVCD2DVD & VOB2MPGReplies: 33Last Post: 6th Aug 2014, 17:45 -
Caputuring HD TV via firewire CAPDVHS on Windows 7?
By Strawson in forum Capturing and VCRReplies: 3Last Post: 16th Oct 2010, 10:31 -
Help... tired of listening to encoded audio
By pixeltweek in forum AudioReplies: 1Last Post: 18th Aug 2010, 04:31 -
Com Surrogate has stoped working
By romanstopme in forum ComputerReplies: 1Last Post: 23rd Feb 2009, 13:16 -
Tired of Windows Movie Maker-What is better?
By jbitakis in forum EditingReplies: 2Last Post: 9th Nov 2008, 14:56
