I have version 2.58 and 2.59 on my computer and they wil not convert ac3 audio to mp2. An earlier setup I used would convert ac3 to mp2. I installed an older version of Tmpeg on my setup,version 2.52 and it wil convert ac3 to mp2 audio diectly. Anyone know why the current version won't but an older version will convert ac3 to mp2 on the same computer?
well in order to convert your ac3 file to mp2 you will have go to mpeg tools and click on multiplex then convert the ac3 file to mpeg file. then it will be able to accept it and convert it to mp2............
Although some people can do the conversion with TMPG, you may find you get a much better result by converting the AC3 with HeadAC3he or BeSweet, and then multiplexing. This way, if you get a 5.1 AC3 you can make the necessary volume adjustments for each track. If you don't, the surround effects can tend to drown out the dialogue. Also, TMPG is not the best prog to do the resampling.
Also, if you want a simple way of converting AC3 to MP2 and y ou are not bothered about adjusting the individual channels, then you can use dBpoweramp.
Audio duration change after transcoding from MP3 to MP2 or AC3
By darklock in forum AudioReplies: 3Last Post: 24th Feb 2012, 16:50 -
Converting MOV to MP2 mux error
By Compufix in forum ffmpegX general discussionReplies: 2Last Post: 30th Nov 2010, 01:38 -
Converting MP2 to any iMovie importable format
By cmlsufan in forum ffmpegX general discussionReplies: 4Last Post: 16th Mar 2009, 01:30 -
Convert MP2 to AC3 within VOB structure
By Xesdeeni in forum Authoring (DVD)Replies: 6Last Post: 4th Jul 2008, 15:19 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24
