hai to all
CHOICE 01 :is there any solution thro which we can convert our DVD to VCD
coz we have realtime dvd encoder so that we can convert our beta to dvd in
realtime with fine quality
..though our final need has to be VCD.
CHOICE 02 :would like to any"is there any real good encoder for doing DV or
BETA to VCD PAL..option 1 is quality & then ofcourse SPEED
toast takes nearly 8 hrs for 1 hr footage though the quality is good..
this is "should i say toooo slow"
pl suggest solution for mac based
& for PC if there is any stable & quality encoder
thanks a lot
note" i read this q in another forum..i too have same quaetion so just placing it here for some help
Results 1 to 1 of 1
thanks 4 inputs
sreni
which Video Quality would you suggest and Why?
By majid_aryaee in forum Newbie / General discussionsReplies: 14Last Post: 27th Aug 2010, 17:48 -
Cinema Craft Encoder Picture Quality
By pboong in forum Video ConversionReplies: 5Last Post: 23rd Aug 2010, 23:17 -
ConvertXtoDVD Encoder Quality
By SCDVD in forum Video ConversionReplies: 17Last Post: 2nd Jun 2009, 13:23 -
Encoder with no quality loss
By JamesDV in forum MacReplies: 25Last Post: 8th Apr 2009, 11:01 -
Fastest but good quality mpeg-2 encoder
By cd090580 in forum Video ConversionReplies: 12Last Post: 23rd Jun 2007, 11:42
