  1. How do I copy files from a vcd to my HD??I was just trying around when I found out that I could just right click on a .dat file in the vcd and click copy and then just paste it into my folder.All I had 2 do was just to rename the .dat file to a mpg....But i noticed the file size was huge(around 35MB) .....what can I do to reduce the file size??like compressing it??I want 2 upload the file on my website and 35mb will take a long time!
    Is there any program that can copy and compress the file at the same time to my HD?Thx
  2. Maybe compress it to a DIVX?...
    http://www.vcdhelp.com/avi2divx.htm
    "Today is only yesterdays tomorrow"
  3. Use vcdgear to convert your .dat files back to mpeg.
  4. i've tried using vcdgui.I tried converting the dat files to mpg and saved it into a folder but the file size is still the same....maybe just a little smaller,about 1-2MB smaller....
