Hi,
I'm a newbee to VCD's, so be gentle with me!
I have created both cd-r and cd-rw discs but in both cases the Panasonic DVD player says NO DISC
According to the list on this site it should play cd-rw's. Has anyone any experience with this model or advice on anything I might be doing wrong or that I could try
I would say that it is definately the type of media you are using, I dont have a Panasonic Player but only certain makes of cdr and cdrw will work with my Samsung 709, if you have a dig around the forum and the dvd player list you may get some suggestions as to what works with your player, good luck.
Standalone player will not play DVD
By Chala in forum Newbie / General discussionsReplies: 12Last Post: 16th Sep 2010, 03:09 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 16:46 -
DVD will play in PIONEER Standalone but NOT Recognise in...........
By rockonvidtrade in forum Authoring (DVD)Replies: 1Last Post: 12th Apr 2009, 23:14 -
problem getting ripped dvd to play in my standalone
By rmb3 in forum DVD RippingReplies: 7Last Post: 25th Jul 2008, 04:16 -
VOB to DVD - Doesn't play in Standalone
By simonsickboy in forum DVD RippingReplies: 9Last Post: 15th Feb 2008, 10:12
