I have digitized an DV .avi file of about 50 minutes. PAL 25 fps
When I want to set a source range, it states the file has 600 fps. Therefore the source range setting menu thinks the movie is only 4 minutes.
Anyone know how this happens? I have checked that the settings are 25 fps, PAL.
This has worked OK before. Just not today. I digitize like I always do, but now I cant seem to fix it. I tried capturing several files... Same result.
I use the latest full version of TMPGENC.
Results 1 to 1 of 1
Y levels outside tv range
By PAL sucks in forum Video ConversionReplies: 3Last Post: 15th Feb 2012, 09:09 -
need to replace audio source with a different source
By sec1968 in forum AudioReplies: 0Last Post: 6th Mar 2011, 22:59 -
Index Out of Range
By bessen69 in forum DVD RippingReplies: 6Last Post: 25th May 2010, 08:34 -
Temperature Range
By Seeker47 in forum ComputerReplies: 12Last Post: 6th May 2009, 16:15 -
AviSynth not recognizing source type (source is animation)
By happypyro in forum DVD RippingReplies: 1Last Post: 5th Sep 2007, 13:48
