Hiya All,
First of all i was wondering whether or not anyone knows why i have a certain problem? the problem is that after i decode a dvd using TMPGEnc i always check it out and have a look at the .M2V file. The video is fine at this stage! Then when i put the whole thing together in DVDMaestro and play the dvd once finished the video will occasionally pause!! Does anyone know why? or if no what other software can i use apart from DVDMaestro!
Also after a little messing around im still not sure it is DVDMaestro coz if i decode the DVD at a very low bitrate then when i use DVDMaestro things come out fine! It only seems to happen when i use a high bitrate!! ANY SUGGESTIONS??
Thanks John
Is the movie freezing when you play it on your PC or on your set top box. I have come across this freezing video problem before. I have backed up quite a few DVDs on to DVD-R, they have all played fine on my Pioneer set top box. However, when I have tried to play them on Sony/Denon players the movie freezes for 1 or 2 seconds every 10 minutes or so. It could be your box is not really DVD-R compat.
VHS to DVD, no Picture Noise. Remuxed it, now it DOES have Picture Noise
By VideoFanatic in forum RestorationReplies: 53Last Post: 20th Sep 2011, 19:42 -
DVD Architect - Pauses between titles, why?
By mjvgiese in forum Authoring (DVD)Replies: 2Last Post: 25th May 2010, 00:12 -
DVD video pauses every 30-35 seconds
By LoopyCoder in forum DVD RippingReplies: 0Last Post: 9th Apr 2008, 14:43 -
Finished DVD pauses for a second every 30 seconds
By shamrockbar in forum DVD & Blu-ray RecordersReplies: 9Last Post: 19th Mar 2008, 12:19 -
Sony DVD Architect 4: Long pauses between video titles
By mltwitz in forum Authoring (DVD)Replies: 3Last Post: 5th May 2007, 19:39
