I've downloaded Pearl Harbor in 3 svcd mpg files. Now I have 2 problems. First I can't extract the sound, cause VDub says its a wrapped mpg. But runnig it through VcdGear has no effect. Why do I want to extract the sound anyway? Because it has a high white noise level. If I can get the sound I want to run it through some noice reduction tool (you know one). Or is there a way of noise reduction directly on the mpg's?
Virtualdub do not support mpeg2(svcd). You can demultliplex the audio to mp2 and convert it to wav with tmpgenc,besweeeeet, winamp
www.vcdhelp.com/faq#demultiplex -
8) Found an easyer way.
If I set my DS-System to Prologic instead of Stereo (which I do in gerneral for SVCD's) the white noise from 4 corners neutralizes itselve.
Free digital voltmeter at Harbor Freight
By jimdagys in forum Off topicReplies: 2Last Post: 20th Feb 2012, 11:08 -
Sobering Cyberwar Scenario on NPR today- Pearl Harbor II
By ahhaa in forum ComputerReplies: 2Last Post: 27th Jun 2008, 20:18 -
Video on the Blackberry Pearl
By Celeste in forum Portable VideoReplies: 4Last Post: 19th Dec 2007, 11:08
