Hello
Can i add more files on a VCD cd?
Let say i want to add a .txt file with movie information in it can i do a folder called "Information" with Nero and add the .txt in it and then burn?
Will it still work on my DVD.
Thanks USiT
With Nero, just drag any additional files you want onto the VCD filesystem. Bingo!
You can do the same with VCDEasy / VCDImager.
Putting additional files on a S/VCD is absolutely fine. I do it all the time (exactly as you do -- an info text file, and e.g., for my Star Trek episodes, I also include an HTM file + pics of the synopsis of the episode from startrek.com).
Just don't muck around with any of the required VCD folders and everything should be okay. If you want to put quite a few files on the VCD, I suggest making a sub folder like "Win" or "Files" or "Extra", etc.
Regards.Michael Tam
w: Morsels of Evidence
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 16:42 -
Use .MTS files in Final Cut Pro while keeping original dates in the files
By Winterburn in forum MacReplies: 3Last Post: 18th Aug 2011, 16:21 -
Why doesn't MKV files play BD PGS/sup files in software or hardware players
By cal_tony in forum SubtitleReplies: 2Last Post: 22nd Mar 2010, 12:10 -
Using Submerge to Join avi Files to srt Files: Problems with Export
By TiggyWink in forum MacReplies: 1Last Post: 26th Jun 2007, 08:16 -
whats best to use to copy my home videos to DVD... avi files or wmv files??
By leegutcher in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2007, 04:24
