On 2001-08-31 08:12:54, buzzinhornets wrote:
Thanx for all the info guys... I'm still a rookie at this stuff, but I'm slowly getting the hang of it. And yes, at some point I plan to convert these avi to mpegs. Also, so most VCDs you buy in a store come as 2 disks? Wow, I always thought they just super compressed the movie onto 1 cd.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Not seen any VCD's in the shops for a long time, they are all DVD's. Asia has VCD's, dont know of any other countries ?
<font size=-1>[ This Message was edited by: letmeinforgodsake on 2001-09-01 03:30:34 ]</font>
Results 31 to 32 of 32
On 2001-08-31 23:48:31, buzzinhornets wrote:
But why in the FAQ about frameserver do they say name the file as "video.vdr.avi"?
Later TMPG versions should accept .vdr as well as .vdr.avi.
Some other encoders do not accept .vdr files, for example cce. Maybe older TMPG versions didn't too, this is just a guess.
Follow the Vdub frameserve guide.
Pay attention at this:
If TMPGenc gives you an error when opening the video.vdr.avi click on Option->Enviromental settings.
And this window appear, click on VFAPI plugin and right click on the DirectShow Multimedia File Reader and select Higher priority.
Now try to open video.vdr.avi.
Remember to after you have encoded the video.vdr.avi to Lower priority on the Directshow Multimedia File Readear to avoid problem open other videos
After finish encoding uninstall the frameserver by running the PROXYOFF.REG.
applying different filters to different sections in a clip (via avisynth)
By unclescoob in forum RestorationReplies: 28Last Post: 30th Jan 2012, 13:50 -
Importing AVI vids into iMovie after applying Vdub filters: is it possible?
By quantice in forum MacReplies: 17Last Post: 4th Sep 2011, 12:48 -
Applying multiple filters at once with FFMPEG
By asterixvader in forum Video ConversionReplies: 3Last Post: 1st Jun 2011, 14:53 -
Applying filters to regions of interest (ROIs)
By johnnys5 in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2010, 16:29 -
Best app for HD-DVD to mkv conversion? With resulting file size around 4gb
By AndyD in forum Blu-ray RippingReplies: 1Last Post: 7th Apr 2009, 07:46
