Whenever I enter the URL of an .ASX file, ASFRecorder only starts converting it about 1 in 20 times.. in other words 95% of the time it dosent work!! All it says isShould I be waiting for something to happen? Or is the program just dead? Any explanations would be good.reply: 200 - OK
200 - OK means that your address is working but ASFRecorder doesn't know how to handle it. If that happens, try using the same address in Streambox....it should work there instead.
For address that are sure to work with ASFRecorder, try going to Rollingstone.com's Video section!! -
lol. Ok.
Funny you should say that about Rollingstone.com, because that happened to be the website that always works on ASFRecorder.
BR - Interesting,If Useless
By wulf109 in forum Blu-ray RippingReplies: 8Last Post: 2nd Aug 2010, 07:58 -
Canon HF200 Useless So Far
By HF200Remorse in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 31st May 2010, 19:55 -
USeless features, dropped divx
By RabidDog in forum DVD & Blu-ray RecordersReplies: 1Last Post: 25th Jul 2008, 14:40 -
N00b question: Is re-encoding useless?Need some advice....
By DavidHazelnut in forum Newbie / General discussionsReplies: 4Last Post: 9th Nov 2007, 19:43 -
DVD+RW ends up useless
By woodlander in forum Newbie / General discussionsReplies: 1Last Post: 25th Sep 2007, 11:32
