Does anyone knows if the MP2 output files from ATI 128 AIW pro can be played with MMC 7.1 or MS MP7.1 when using the SVCD settings to capture the file?
My settings are
Card: ATI AIW 128 pro
PC: AMD Duron with 1.2GB memory
Format: MPG2
Dimension: 480x480
Bit Rate: 2.3 VBR
Motion Etimation: ~50%
I am using all the settings recommend for SVCD but when I try to test the file.mp2 using the "File Player" my Win2k just freezes. I try using MS Media Player 7.1 and it just give me an error complaining could not find correct Codec.
I re-installed drivers, MMC 7.1 and SP2 for Win2k, in that order, and keep getting the same problem. Is the MP2 file playable using MMC7.1 or only DVD players (wiht VCD capabilities) can play that file. Do you have any Ideas?
Thanks in advance for any help you can supply.
Thanks,
Roberto Tijerino -
Rename the MP2 extention to MPG. That will solve the problem on a Manual basis.
On 2001-08-27 15:50:36, Greg12 wrote:
did you install the dvd upgrade.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
I read that a similar problem, I will try tonight. -
I finnaly got to install the DVD player applet and everything works just fine. Thanks everyone for the advice.
I hope this will help someone else as it helped me.
Thanks,
Extract .m2v and .mp2 files
By geohei in forum Authoring (DVD)Replies: 3Last Post: 15th Sep 2010, 13:42 -
MPEG2 files of VOB2MPG not accepted by ATI AVIVO video converter
By 33M344 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 13th May 2010, 14:53 -
Merging MPA video and MP2 audio files
By makf in forum Newbie / General discussionsReplies: 2Last Post: 7th Jul 2009, 20:13 -
M2V + 2 WAV files to VIDEO_TS with 2 PCM soundtracks (not mp2)
By cleantone in forum MacReplies: 14Last Post: 28th Aug 2008, 16:10 -
Why MP2? Then why failure?
By Gripweed in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 22nd Jun 2007, 06:32
