I just burned 2 movies in the kvcd format. Great quality and holds one movie per CD (smaller than svcd?!) What is this format?
=[ vinchi007 ]=
are you teasing ???
1) how do you encode your video ? which tool ?
2) format: MPEG-1 or MPEG-2 ?
3) burning: What tool do you use to burn your KVCD ? firewood ?
maybe mispelling ? XVCD instead of KVCD.
BTW, since you burn the disc yourself, how do you know to choose KVCD.
I am exremely curious.ktnwin - PATIENCE -
Kvcd is another type of xvcd. There are several kvcd templates that hold from 60-180 minutes. Check out www.kvcd.net for more info. Hope this helps.
Simply put, KVCDs are non-standard VCDs, similar to XVCDs
"KVCD" is not a standard.
You can find more info here:
http://www.kvcd.net
and FAQ are in the forum here:
http://www.kvcd.net/forum/viewtopic.php?t=68"speed's just a question of money. How fast can you go?" - Mad Max, 1979 -
thanx alot for info m8s.
And ktnwin - I got this movie from a friend of mine in bin image file. Do you know every different XVCD format? I don't. I don't even know the specs for kvcd and want to get some on it! Is that wild west for ya?=[ vinchi007 ]=
KvCD to vob
By natty in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2010, 15:37 -
KVCD
By Bat21UK in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2007, 15:31 -
2 hours plus on one kvcd - how?
By t41 in forum Newbie / General discussionsReplies: 1Last Post: 16th Sep 2007, 11:08 -
Xvid to KVCD
By mjaeson in forum Video ConversionReplies: 8Last Post: 25th May 2007, 20:05 -
KVCD to DVD
By buttzilla in forum Video ConversionReplies: 2Last Post: 6th May 2007, 08:01
