  1. Hello all, It never fails to amaze me this Dvd ripping thing, Just when you think you've got the jist of it eh, The thing that's confused me is that about a week ago i ripped Ice Age, I did'nt need to compress it because the Vob's and Ifo i ripped was big enough to fit on a Dvd-r, I had a few problem's at first but with the help of this Forum i eventually done it, All i had to do was get the Vob's etc, Put them in to a Directory called VIDEO_TS then burn them with Nero under the setting's DVD ROM( UDF), Instead of DVD Video, It worked great, However i just ripped Evolution the same with the Vob file's being small enough to fit on Dvd-r, Done it the same way as Ice Age, It did'nt work, So i tried Using
    Dvd Rom (Udf/Iso) instead and that did'nt work??, It's R2 by the way same as Ice Age, Any idea's on this would be so appreciated, Thank's,
    Also i forgot to mention that i set the Udf to 1.02 like i did with Ice Age, Have i got to set this different??
  2. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    I did evolution r1 using just ifoedit to strip unwanted stuff. Then burned Using Nero and UDF/ISO, works perfect for myself. Perhaps you did something wrong?
    One topic is enough.
  4. One topic is enough???, You mean because i repeated this?, The reason being is because some people may of missed the previous one's, Like the people who may know the answer to my problem, Unlike yourself, Or maybe you do but can't be arsed to type, Thank's for your reply any way, Even though "One topic is enough" Was'nt any help,
