    Jul 2002
    I want to set my PC to convert several files to MPG for VCD burning but I only seem to be able to set it up to do one at a time...the batch option keeps telling me the file format is wrong.....although it works ok as a single file
    Help please
    Apr 2002
    The State of Frustration
    What are the original files, and what selection are you using in the wizard?
    Hello.
    Jul 2002
    Using FILE BAtch encode ADD
    When I try to add a DIVX (AVI) File I get Illegal stream format
    I want to add a list of DIVX files to convert as a batch method
  4. Originally Posted by ukcalibrauk
    You dont add source files to the TmpGenc Batch mode, you add Tmpgenc project files.
    Setup up Tmpgenc for the 1st encode and select file->save project.
    repeat for all other files you want to encode, I suggest naming the project files along the lines of pro1.tpr, proj2.tpr. Now add these project files to the batch control list and click start.
    Jul 2002
    Thanks that explains it
    Calibra
    Jul 2002
    mmmm
