I am planning to put my burner to external enclosure. It should be Firewire since I have Firewire on home PC and Laptop (no USB2 only 1.1). I found this one on the web.
CD-509 5.25-inch Firewire External Enclosure Case for $48 (Genesis or somethink like that chipset)
Is it good one ? Or is there something that is tested and for good price ? What should I check before I buy one ? Is there somthing that I should avoid ?
Thanks.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 1 to 30 of 80
http://www.scsipro.com/catalog/pg23_firewireidecasekits.htm very very good
http://www.esbuy.com/newallalen.html really good also (i use these) -
There are some dual firewire/USB2 enclosures out there also that might be worth a look.
Panasonic DMR-ES45VS, keep those discs a burnin' -
OT: sorry for asking, but what is a "Thick moderator"? i hope it does not mean something bad? :P
everyone knows that -> a "thick Moderator" is used to shield Neutrons in a reactor or also to slow down a radioactive proccess or chemical proccess. You could use a thin one also - if you got guts..
oh and used to block gamma rays also (VERY difficult - don't try this at home!!) -
Hmmmm..... yes Durex is too thin for those particles
Originally Posted by BJ_M
BTW, very dense materials are usually used for shielding gammas and in general are not good moderators (at least in the nuclear sense). -
Yes, BJ's links look to be great if you like overpaying for
enclosures. You can get oxford911+usb2 combo enclosures through etailers for about $90. For example:
http://www.triumphtech.com/@PRDCT/TT345.htm
which is what I got for my dru500a.
I've seen this enclosure resold elsewhere for basically the
same price, but usually for more money. The firewire only
enclosures are a bit cheaper.
Also non-oxford 911 enclosures seem cheaper, and
skimping on power supply (getting one that is under-rated)
can probably save you a few bucks.
Note that firewire bridges don't necessarily handle IDE errors
the way one would expect (mine doesn't report CRC errors that
occur on read or write). Here's my rant on that topic from another
thread:
I think there are a couple dirty secrets about IDE/Firewire bridges. (I
suspect the same is true of the IDE/USB2 bridges but I have no experience).
First, configurability. People have problems with firewire enclosures due to
things such as which UDMA mode is negotiated, and how many seconds the
controller waits before probing the device. Oxford's firmware utility lets
one configure such parameters, but the utility has not been made widely
available. I see no enclosure retailer who supports configuring the firewire
bridge through such a utility, even though one may very well need to in order
to get their device to work. These enclosures are marketed as if they
are plug and play, but they aren't necessarily.
[Update: apparently adstech does allow configuring the device type in
their oxford 911 based enclosure.]
Second, error detection and correction. When I first put my dru500a in
a firewire enclosure, I got a bit error every 2MB or so during DVD writes.
My writes would be corrupt without any error being reported. Tracked
the problem down to the IDE cable being too cheap, producing cross-talk.
An internal IDE controller would detect such errors.
Later, I attached an IDE disk into a firewire enclosure. The disk contained
data errors. With the firewire enclosure, the OS read past the errors
with no error reporting (data was merely corrupted on read). Plugged
in internally, the IDE controller reported CRC read errors for this same
disk...
Does USB2 have these same problems? If not, it is clearly the winner. -
bac, are you saying that Firewire enclosure is not good for DVD Writers ? I am cofused.
What would be disadvatage if I buy non-oxford 911 enclosures ?
I am not sure what do you mean by "skimping on power supply (getting one that is under-rated)". -
i have burned 100's and 100's dvd's in firewire enc. with no problems.. i suggested the more expensive cases because they have heavy duty power supplies , bearing fans (and dual fans in some cases) , and ata 133 rated internal cables , proper shielding of both the case and also the power supply IN the case.
there are cheaper solutions, i just know what works ..
firewire drives and dvd burners are used by 1000's and 1000's of people and are very popular in the video editing bussness.. as well as on apple computers (who invented firewire) ..
it is true accessing an external firewire hard drive - there is delay .. some are better and some are bad (maxtor bad , acom good for example) .. we have around 100 external firewire hard drives floating around here , i have 8 x 120 and 160 firewire external drives hooked up right now along with 2 dvd burners -- and they are all going at once (burning two different dvd's same time) .. this is off a ads pyro card with the extra power supply cable attached to it .. -
Manufacturer link - http://www.a-tec.com.tw/ourproducts41.htm
The $48 CD-509FW looks best to me and here is the USB 2.0 model - CD-509U2 for $45.
http://shop.store.yahoo.com/4itech/cool35usexen.html
I can't find one which sells CD-509Combo.
I'll also use Sony DRU-500A in Firewire/USB 2.0 enclosures. It's South Korea's voting day for the presidential election so I'll get them tomorrow. -
oh -- i have one of those exact cases in BAC's post from http://www.triumphtech.com/@PRDCT/TT345.htm (same case but i got it shipped to me by esbuy (by mistake))..
going to test it out tonight ... first i notice is it has a bushing fan and only a small looking 2.2 amp power supply vs a larger one on most of my other cases .. but it does have the very latest firewire bridge board made by rainbow -- who makes good parts ... -
Waiting for your testing results ....
Is your FireWire ?
And what about this Genesis chipset ? Is it bad ? -
it is working fine with a 105 pioneer .. yes it is dual firewire/usb 2 but i only use firewire as i dont use usb at all
More and more confused (maybe it is because I wan't chep one )
These are that I found
TT-345 Series (OxFord 911) $69
CD-509-FW Series (Oxford-911) $53
ME-320F (Oxford-911) $49 (you can see this everywhere but nost sites does not provide info about Chipset)
Now I hate this on the web
We are not responsible for typing errors. All information in the web are for reference only, please go to manufacturer web site for more detail information
BTW: Who manufactores these ? -
http://www.audioexchange.com/52me313firex.html
it has the oxford chipset says this web site -
Yes ... but on the same page you can see this.
We are not responsible for typing errors. All information in the web are for reference only, please go to manufacturer web site for more detail information -
Originally Posted by donpedro
I believe my fear is correct... another info from some web
Coolmax CD-509FW 5.25 Firewire External Enclosure, compatible with CD-ROM/CD-R/CD-RW/DVD-ROM and 3.5 Hard Drive OS Support Win98/SE/ME/2000/XP, Mac OS8.6/9.X/10.X or above, included Firewire Cable. Ask for chipset -
For example, when I first tried my dru500 in an external
case (with oxford911 based bridge), I had a cheap IDE cable.
The IDE cable had wires that were split, and could overlap.
This created crosstalk, and generated ~1 bit error every 2MB or
so. The IDE controller in the oxford911 chip did no error
detection, reporting, or correction. The errors were passed to
the DVD-R disks silently. Ie errors in your burn result.
Took a couple days to figure this out.
Pre-oxford 911 bridges were reported to be lower in performance
than the 911. (For example the oxford 910). I am not
sure about the current generation of alternative bridges, such
as the initio. I haven't seen any performance test results for them.
An example enclosure with initio bridge:
http://www.ioiusb.com/products/prod_detail.asp?ProdCategory=USB_to_IDE_Enclosure&ProdN...=U2FWEIDE525-1
By skimping on power supply, I mean one whose 12V and 5V amp output ratings are not sufficient for a 4X DVD burner. The
DRU500s label has higher requirements than what I've seen
on any other burner so far (not that I've done a study), so I
wouldn't assume any 5.25" enclosure's power supply will do.
A power supply that barley meets the current requirements of
the DRU500 could burn out quickly I'd think. I had an external
enclosure power supply burn out on me a few years ago... -
Data write errors may be rare. In my case the cable was 40
conductor but the bridge board was allowing UDMA3/4/5,
which means a mismatch. I've read that such
a mismatch can lead to data errors. Which goes to my point
about configurability of the bridge boards.
Anyways, such pitfals can exist even if thousands of non-technical
users are bying the gear.
Also note that I experienced CRC read errors
not being reported by the firewire bridge board when I was
reading from a hard disk with known disk errors. At that point
I was using a quality 80 conductor IDE cable. -
I use the Sony in a Qtec USB2 ALuminium Case Case. This works very well.
Only had problems with Alcohol 120% but Nero, RecordNow etc works just fine.
Site: http://www.qtec.info/
http://www.qtec.info/products/product.htm?artnr=13280 -
bac - you are certanly correct in that there is often a problem with cables -- not only in external cases but i have seen a very large % of pullout drive bays (you know those plastic drive sleds) that have a lot of problems with bad data and bad transfer ... due to one; they introduce an extra connection in the middle of a ide cable , and not a very good one at that . And second ; they often use cheap cables internally (like those split folded cables are the worse) ... i have seen many times an ata 133 cable external and internal they are just 40wire.
i also have seen a number of bad ide cables -- specially some of those rounded designer cables are verry cheaply constructed ...
AS for the oxford chipset -- be aware that Oxford 911 bridges can differ in overall performance (firmware may be an issue here); and, second, other new-generation FireWire bridges, such as Indigita's, can match Oxford 911 performance.
Newest versions of oxford and Indigita do error checks i understand (and are ata133 internally).
Some older oxford chipsets do not work at all on mac os-x and this is a problem for a lot of mac users..
cant wait for serial drives ...
but all in all - firewire is a great way to go -
Is this what I should be looking for ?
Originally Posted by From Sony's manual
Originally Posted by From cheap enclosure
--edited--
OK... I see now... This is what I need to look for
DC Output: +5V 1.5A/ +12V 1.8A -
That is only the input current - the output current isn't really specified.
I just ordered one of the USB/firewire enclosures (TT-345U2F from www.aicmicro.com for $79 plus shipping so we'll see if it's ok. If it won't hold my Sony I'll put a 120Gig HD in it.Panasonic DMR-ES45VS, keep those discs a burnin' -
I have a external 3.5 firewire enclosure from http://www.firewiredirect.com. It has the Oxford 911 chipset in it and I'm not at all happy with its overall performance. I don't know whether its the 911 chip or the internal cabling or the enclosure firmware but it's nowhere near 40 MB/s.
The enclosure itself is very nice looking and made of good quality parts.
Here's a link to the enclosure. I have the 3.5" Ultra III with FireWire & USB 2.0. http://www.firewiredirect.com/firewire/products/drivekit.shtml
External HDD Enclosure Question
By Timex in forum ComputerReplies: 4Last Post: 1st Aug 2011, 13:53 -
External Harddrive Enclosure
By AuroEdge in forum ComputerReplies: 0Last Post: 3rd Jan 2010, 12:20 -
External 1.5Tb hardrive? i cant Choose one!
By Entry in forum ComputerReplies: 14Last Post: 9th Sep 2009, 22:41 -
This External hdd enclosure only confuses the sata vs eSata issue for me
By gll99 in forum ComputerReplies: 13Last Post: 12th Mar 2009, 21:01 -
Have they created an external enclosure for pci cards?
By yoda313 in forum ComputerReplies: 13Last Post: 21st Aug 2008, 22:58
