  1. Im using a sony DRU500 with the newest firmware. Im trying to use dvdxcopy it seems like everything works fine throughout the burn process however when i got to play the movie i just get the warning screen that 321 put on it...thats it..no matter where i play it ..my computer or my three standalone dvd players....any ideas?? Ive been using the default dvdxcopy burning software. thanks
  2. i dont know the answer but i have a tip to stop you burning coasters.
    when you get to the part where it asks you to burn (if two parts disc 1)
    open windows explorer and cut the files dvdxcopy created and put them in a different folder then press skip this disc to carry on.
    as you know if you did press skip this disc it would delete what it has just created.
    then you can use power dvd or whatever to try it before you burn.
    thingimijig.
