I've done a search of the forum and i 'think' I came up with the answer but would like confirmation please.
I encoded a film to SVCD from .AVI using TMPGEnc'.
The source framerate was 23fps and I encoded to NTSC Film.
I've got excellent results apart from this problem. Every now and then the picture 'scrolls' vertically for a second or two (just as if the T.V. wasn,t tuned in properly). It plays fine on my P.C. and I've burned it twice with the same result
Now then, I think the problem is I live in the UK, PAL land, and maybe my T.V. is objecting to the NTSC thing.
What do you, my learned friends, think?. This is the post I found. Thanks.
http://www.vcdhelp.com/forum/viewtopic.php?t=78178
Results 1 to 12 of 12
I think you are probably rigth. Take a look at your DVD players setup options, some can be changed to output PAL-60 in the case of NTSC playback. Your TV may handle this better than true NTSC.
Good point Miketree, I posted a question earlier regarding framerates and I was told that If I encode a 23 fps film to NTSC I would lose the jerkiness, so I did, and it did.
Thx also bugster, I'm checking it out.
This frame rate issue, 23/23.976/25/29.97........is something I'm struggling with. I need to try and understand how to convert from one to another, when I need to do it, and If I need to do it...
I'll get there with experience I reckon....Thx for help -
If your DVD Player/TV support NTSC (and most European ones do) then there is no pint converting from NTSC framerates to PAL. This kind of conversion is possible (well, 23.97 or 24 to 25, 29.97 is a different matter) but the process is long winded and full of holes waiting for you to fall into. Because of this, I always recomend, if you don't HAVE to do it, then simply don't bother, its not worth the effort.Originally Posted by ABAB
Where on earth did you get 23 fps? That framerate doesn't exist in nature.
Playing 23.97 NTSC Film on a Pal machine will cause some hiccups. Depends on the machine, and how it deals with other formats. Mine plays PAL onto NTSC with no problems.
Relaisticaly, there are many guides to convert Film (24fps) to Pal(25 fps) or NTSC (30 fps) (approximate fps's). You didn't say what you encoded to, how you did it, or what you are playing on. -
When I encode to Mpeg2, would just choosing the closest framerate do it? (assuming my source was not PAL, NTSC or NTSC film to start with).
23 fps? Well, if you take an avi encoded at 23.97 fps and look at the file properties under winXP (right click file, properties, summary tab) it will show a framerate or 23fps)Originally Posted by Gazorgan
SVCD at 23.97fps should have 3:2 pulldown applied.
Convert from NTSC to PAL. Why bother if it isn't needed. -
I did say what I encoded it on and how, I try to give as much info as poss'.
Bugster, "You said SVCD at 23.97 fps should have 3:2 pulldown applied."
What do you mean?.......when I encode from .avi?,
Here's what I do to encode.
Source.....23 fps .avi file
I would load the .WAV and video into TMPG enc' and choose NTSC film and SVCD.
select whatever filters I might need and then set it going.
I don't select 3:2pulldown under the advanced tab, should I.
I know I'm struggling to understand this but I know it will click soon.
Thx -
If you are using the supplied SVCD NTSC film template then you should be ok. I just checked it and it does set everything up correctly for 3:2 pulldown (as you would expect I suppose).Originally Posted by ABAB
Yes, I start with the supplied template then tinker with a few settings that I know give me decent quality and that's it.
At no point is 3:2 pulldown ticked.
I think I'll have another night of experimenting. Dig out the Re-writables again I reckon.......
Thanks for staying with me and I'll post back later with findings.
Thx
Restoring "Safe To Remove Hardware" Popup Confirmation
By CobraPilot in forum ComputerReplies: 8Last Post: 3rd Jan 2012, 12:35 -
New to FFMPEG-confirmation on ipod code
By smike in forum Newbie / General discussionsReplies: 1Last Post: 21st Aug 2011, 23:45 -
Conference recording, system design confirmation please!
By boasist in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 12th Jul 2011, 09:32 -
Need confirmation of this SUPER settings to copy stream from FLV to AVI
By ohboy888 in forum Video ConversionReplies: 2Last Post: 20th Feb 2009, 04:59 -
WXP copy confirmation reverts to "Yes"
By walter4h in forum ComputerReplies: 0Last Post: 26th Oct 2007, 20:14
