some idiot converted the header of an svcd to a vcd, and i want to convert it back. can someone please tell me how?
Use TmpGenc, mpeg tools. Select the simple multiplex tab. Add your mpeg as both video and audio source, select an output filename and only then set Type to MPEG-2 Super VideoCD (VBR)
Tell nero to shove it and burn anyway, then test your disc. Nero seems touchy about non-compliant mpegs. Mine always work anyway, use a RW disc if you dont want to waste on a test
Header stripping
By NikkiSix in forum Newbie / General discussionsReplies: 46Last Post: 17th Feb 2013, 18:57 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 20:40 -
Rewriting header
By DVDONE in forum Video ConversionReplies: 10Last Post: 17th May 2010, 16:11 -
Conversion divx to svcd gives Choppy Playback
By Soixante in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 07:25 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 10:11
