  1. Hi folks
    Sorry for posting twice, but i got no answer 4weeks ago at Newbieforum and I didnt find any solution. So can anybody help me?
    I´ve got one simple question: I wanted to encode an .AVI as SVCD using DVD2SVCD. everything works all right, until DVD2SVCD comes to the point "Executing Frameserver". It opens the VFAPI ReaderCodec v1.04 BETA and there it stucks. Nothing else. When I close the Window by pressing exit DVD2SVCD (or in this case AVI2SVCD) says "Executing Frameserver: Program Handler not found". What does this mean?
    I´m using DVD2SVCD 1.0.9 build3 (the AVI2SVCD is v1.0.9 build3). I tried with CCE 2.50 and CCE 2.46, but I think it has something to do with AVISYNTH.
    MovieID says:
    File Format: Audio-Video Interleaved (AVI)
    Author: Microsoft Corporation
    Web Site: www.microsoft.com
    Content: Video and Audio
    Duration: 49 min 48 sec
    Data Rate: 2151 kbps (ave)
    Video Info: 720 x 576, 25 fps
    Audio Info: 44100 Hz, 1411.2 kbps, stereo
    Video Format: DivX version 4
    FourCC: "divx"
    Author: DivXNetworks, Inc.
    Web Site: www.divx.com
    Can be played with DivX version 4 and later codecs.
    Audio Format: Microsoft PCM Format
    Format ID: 0x0001
    The DVD2SVCD-Log file looks like this:
    Audio conversion of D:\Filme\recent\Extracted_audio_1.wav finished.
    Audio conversion finished.
    - 07.12.2002 12:53:53
    - Free on drive D: 3667.41 mb
    - Video Encoding using Cinema Craft
    Executing Frameserver.
    - 07.12.2002 13:01:29
    - AVI to SVCD Conversion
    - AVI2SVCD ver. 1.0.9 build 3
    Initializing
    Initializing finished.
    - 07.12.2002 13:01:37
    - Free on drive D: 4174.25 mb
    - Crash Recovery
    - Restarting from: Video encoding
    - 07.12.2002 13:01:40
    - Free on drive D: 4174.24 mb
    Program Handle not found, terminating program.
    Please help!
    Thank U
    Diver
    Welcome - to the real world
  2. I'm having the same prob!
    It stucks after "Executing frameserver", it actually adds the job and I
    can see that convert has been pressed, but then nothing happens.
    I think DVD2SVCD(my version: 110B1c) works with the "Sendkey"
    method to get the external tools like the frameserver "VFAPIConv-EN.exe"
    or CCE/TMPGEnc working, so I think it is maybe too fast, means
    frameserver isn't ready yet to do the next job.
    Funny thing is it worked yesterday, now that I've reinstalled the NimoCodec
    pack today it doesn't work anymore.
    Either a sendkey prob(too fast or maybe the wrong keys) or a new/missing codec.
  3. I did a few tests and found out that with enabled option "Encoder"->"Safe mode (frameserving)"
    for CCE vewsions higher than 2.50 it didn't work, at least for me.
    I'm running DVD2SVCD with CCE2.50 right now, maybe u should try to disable
    this option.
  4. Well i tried version 2.50 and it didn´t work. But I also have a newer version of Nimos Codec pack.
    You said that You´re running DVD2SVCD with CCE2.50 right now. Does it work now? What system do u have?
    With Win2K everything worked all right, but now i use WinXP. Perhaps the error is there?
    Diver
  5. Originally Posted by Diver
    Win 98 SE.
    Maybe u should just remove the whole Nimo Codec package and only
    install the basic version, I don't know. Btw, I thought 5.08 was the
    latest Nimo Codec, isn't it?
    Good luck
  6. Well thanks
    I´ll give it a try
    Diver
