I have a movie I had on the net in divx but I can't hear the sound when I play it; I don't know what codec it uses. Any suggestion?
Install the codec? Try opening in vdub and looking at the file information for the audio codec. You may also try installing the Nimo Codec pack, and only installing the audio codecs.
There is a program called gspot which will tell you what codec you need. Use google or your favourite search eangine to find it coz I can't remember where I got it from!
DivX Audio problem which has always bugged me..
By SE14man in forum Newbie / General discussionsReplies: 4Last Post: 4th Nov 2011, 08:36 -
DV Type-1 to Divx video/audio sync problem.
By cgmarsh in forum Video ConversionReplies: 0Last Post: 10th Aug 2010, 15:35 -
Avi to Divx audio problem
By win993 in forum Video ConversionReplies: 4Last Post: 25th Sep 2008, 17:53 -
MPEG to Divx audio sync problem
By starless in forum ffmpegX general discussionReplies: 8Last Post: 11th Oct 2007, 04:38 -
DVD to Divx conversion - Problem with audio ! Please Help
By sharartie in forum DVD RippingReplies: 1Last Post: 23rd Aug 2007, 04:13
