I posted a message yesterday - got a reply from markrb-cheers for replying, he pointed me to the rules saying post up your log file-sorry, here it is-thanks again to anybody how can help us out:
dvd2svcd_log.txt
WNASPI32.DLL 4.6.0.1021
- 17/12/2002 20:07:03
- AVI to SVCD Conversion
- AVI2SVCD ver. 1.1.0 build 1c
Initializing
Initializing finished.
- 17/12/2002 20:07:07
- Free on drive G: 9066.83 mb
- AUDIO Extraction
Audio extraction finished.
- 17/12/2002 20:08:04
- Free on drive G: 8974.90 mb
- AUDIO conversion
Encoding Audio. Filename: G:\My DVD Data\Movies\DVD-SVCD Output\Extracted_audio_1.ac3
Executing BeSweet. Commandline:
"C:\Program Files\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "G:\My DVD Data\Movies\DVD-SVCD Output\Extracted_audio_1.ac3" -output "G:\MYDVDD~1\Movies\DVD-SV~1\Encoded_audio_1.mp2" -logfile "G:\MYDVDD~1\Movies\DVD-SV~1\Encoded_audio_1.log" ) -azid( -L -3db -c normal -s surround -g max ) -shibatch( --rate 44100 ) -2lame( -e -b 192 -m s )
Audio conversion of G:\My DVD Data\Movies\DVD-SVCD Output\Extracted_audio_1.ac3 finished.
Audio conversion finished.
- 17/12/2002 20:33:34
- Free on drive G: 8882.93 mb
- Video Encoding using Cinema Craft
(Then i gett a message in cce, saying:
Frame size 756x56 is not supported. Supported Frame size is up to 756x560)
Avisynth_Script_file.avs
LoadPlugin("C:\PROGRA~1\DVD2SVCD\MPEG2Dec\mpeg2dec .dll")
AVISource("G:\MYMUSI~1\JAMESB~1\007DIE~1.AVI",Fals e)
ConvertToYUY2()
BicubicResize(480,368,0.0,0.6)
AddBorders(0,56,0,56)
ResampleAudio(44100)
Thanks in advance for anybody who replys
I began converting some divx movies,to svcd using cce,but began getting strange results!The movie was fine-but had a purple haze over it!i put these movies aside but cant figure what im doing wrong-i though i might not hae the correct codecs installed so i made a stupid movie of uninstalling all my codecs,players etc - now it wont convert at all! My questions are below:
1.)
Im getting a message in cce
The codecs i haev installed are:
Nimo.Codec.Pack.5.Build.7. - Shareactor
XviD_Install - From Divx Digest
Aspi
ASPI32.SYS V4.6(1021)
WOWPOST.EXE V4.6(1021)
WINASPI.DLL V4.6(1021)
WNASPI V4.6(1021)
it also says:ASPI is properly installed and full operational
dvd2svcd v 1.1.0 Build C
cce 2.5 SP Version 2.50.01.00 (SDK Version ) (at he top of cce it says SP --noname)
I read somewhere you should have too many-are these enough?am i missing some/a lot?
I thought while waiting to get cce to work again i would us TMPG but that aint working now either it comes up with errors while encoding the movie something like "a00010181" and i need to click "OK" then another comes up-this continues-i dont know if that is another thing altogether!
2.)
My computer seems to play wav files i create using audio programs but when i try to rip the audio from a divx movie in virtual dub it comes up with an error:
The Requested audio compression is not compatible with the input formate.Check that the sampling rate and channel count of the input match of the requested format
In roxio it i split the audio&video but it seems to not know what wav file is. In sound forge it said the wav file is unsupported!
Im following tutorials exactly i think im missing something have been stuck with this problem for ages. Can any experts out there help me out with a solution?Cheers again
Then why dont you change it to 756x560 and not 756x56???Im getting a message in cce Frame size 756x56 is not supported. Supported Frame size is up to 756x560-Yar, matey!-
cheers for replying,i have been looking for ages but cant find an option in dvd2svcd or cce to change the frame size - i thought i was missing a aspi driver codec thing!im gonna ask a stupid question can you tell me were to change this frame size
cheers again
mr_rasta -
I...uh...cant really answer that. If you use the original DVD2SVCD template for an svcd, it should automatically set it to the right resolution.
Also: What is the size of the original AVI that you are using?-Yar, matey!- -
just open the txt file and change it - then use dvd2svcd resume feature
you wil be able to spot it right away -
mr_rastaman
Goto the misc Tab in DVD2SVCD, in the DVDS2SVCD level window put that to advanced.
Now goto the Frameserver Tab and you should now have the resize to option at the bottom.
Hope that helps -
thanks again for replying guys!
im really bad at explaining this-always thought dvd2svcd was excellent time it takes it amazing compared 2 tmpg-just it seems to have went totally pearshaped!
The dvd2svcd log txt file says this :
- 20/12/2002 01:24:04
- Free on drive G: 7939.46 mb
Executing Frameserver.
Closing program
The audio part is fine (i think) cause all the .wav & .mp2 files seem to work just the cce bit!
I have the advanced tab clicked-when to Frameserver Tab and have already hightlighted svcd 480x576 - dont know why cce or even better i dont know where it is getting "756x56" from!really doing my head in! u have resulted in using this mvcd template for tmpg - converting just know meant to be good - but i doubt anywhere near as good as cce!
thanks again in advance for any help
mr_rasta
I thought i would post my dvd2svcd.ini file, i dont know if there is info in that which can help-i can see shit in there!thanks
CDSize 2=800
CDSize 3=740
CDSize 4=800
CDSize 5=740
CDSize 6=800
MaxBitrate=2530
MinBitrate=300
MaxAvg=2230
MinAvg=1600
Adjust Audio Bitrate=1
Use Min. Avg.=0
Force Film=0
Movie Offset=2
CDOverlap=2
Data Preparer=dvd2svcd
Use I-Author=0
Use VCDImager=0
No images=1
Use VCDXBuild=0
Length of Chapters=60
Use TitlePicture=0
Use ChangeCD Picture=0
Avisynth Bicubic b Value=0
Avisynth Bicubic c Value=0.75
SmartDeinterlace Mode=2
SmartDeinterlace Treshold=10
SmartDeinterlace Denoise=1
SmartDeinterlace Blend=0
SmartDeinterlace Fast=1
Edit Avisynth Script file=0
UseAVI2SVCD=1
UsePVA2SVCD=0
UseDVD2SVCD=0
UseCDOverlap=1
FirstRun=0
Use CDMage=0
RunPerCDImage=0
RunFinal=0
RunPerCDImage Params=
RunFinal Params=
bbMPEG videoDelay Adjustment=180
bbMPEG audioDelay Adjustment=180
bbMPEG audio1Delay Adjustment=180
Use MPEGAV=0
FixedChapters=1
DVDChapters=0
ForceIAuthorSupport=1
TMPGEnc Rate Control Mode=2
ResizeMethod=2
Auto Intra DC=1
DC component precision=0
Avisynth Setup=BicubicResize
Frames pr spread=25
Spread=100
UseMPEG1=0
UseMPEG2=1
Convert to Canopus codec=0
Convert to Divx4=0
Use Frameselection=0
New Default Folder=0
DVD2SVCD Level=1
Eject DVD=0
Luminance Gain=0
Luminance Offset=0
Audio1Downsampling=1
Audio2Downsampling=1
Audio1BitRate=9
Audio2BitRate=9
Folder Structure Source=
Folder Structure Video=
Folder Structure Audio=
Folder Structure Muxed=
Folder Structure Subs=Subs
Intra=8,16,19,22,26,27,29,34,16,16,22,24,27,29,34, 37,19,22,26,27,29,34,34,38,22,22,26,27,29,34,37,40 ,22,26,27,29,32,35,40,48,26,27,29,32,35,40,48,58,2 6,27,29,34,38,46,56,69,27,29,35,38,46,56,69,83
NonIntra=16,17,18,19,20,21,22,23,17,18,19,20,21,22 ,23,24,18,19,20,21,22,23,24,25,19,20,21,22,23,24,2 6,27,20,21,22,23,25,26,27,28,21,22,23,24,26,27,28, 30,22,23,24,26,27,28,30,31,23,24,25,27,28,30,31,33
Matrice Preset=
Use deafult Matrice=1
LFEDownmixLR6Ch=-3
LFEDownmixLFE6Ch=0
CenterDownmix6Ch=0
SurroundDownmix6Ch=0
DynamicCompression6Ch=1
StereoDownmixType6Ch=0
RearChannelFiltering6Ch=0
DialogNorm6Ch=0
LFEDownmixLR2Ch=-3
LFEDownmixLFE2Ch=0
CenterDownmix2Ch=-1
SurroundDownmix2Ch=-1
DynamicCompression2Ch=1
StereoDownmixType2Ch=0
RearChannelFiltering2Ch=0
DialogNorm2Ch=0
No Audio Conversion=0
Flip Vertival=0
Add ResampleAudio=1
Resize To=0
Use CCE=1
Use TMPGEnc=0
CCE Safe Mode=1
RoBa Multi Pass=0
RoBa Visibel=0
CCE Bias=20
CCE Field Order=2
Progressive=1
DVD Compliant=0
Restrict auto I frame insertion=0
Close all GOPs=0
Intra DC=2
M GOP=3
MN GOP=5
SEQ Header=1
Constrained Parameter Set=1
TMPGEnc Motion search precision=4
TMPGEnc Field Order=2
TMPGEnc Num of passes=2
Prediction Size=0.999
OffsetFixed CQ Value=80
OffsetFixed CQ_VBR Value=25
Use fixed CQ Value=0
Output YUV data as Basic YCbCr not CCIR601=0
Use floating point DCT=1
No motion search for still picture part by half pixel=1
Soften block noise=0
Soften Intra=35
Soften NonIntra=35
TMPGEnc GOP I Pictures=1
TMPGEnc GOP P Pictures=4
TMPGEnc GOP B Pictures=3
TMPGEnc SEQ Headers=1
TMPGEnc Max frames in GOP=0
TMPGEnc Close GOPs=0
TMPGEnc Detect Scene Change=1
Enabled Padding=0
TMPGEnc VBVBuffer=0
SubOutputPalette0=clBlack
SubBlendPalette0=0
SubOutputPalette1=clWhite
SubBlendPalette1=15
SubOutputPalette2=$001E1E1E
SubBlendPalette2=15
SubOutputPalette3=clGray
SubBlendPalette3=15
Resize Subtitles=100
CVD subtitles=0
bbMPEG MPEG1=0
bbMPEG VCD=0
bbMPEG MPEG2=0
bbMPEG SVCD=1
bbMPEG DVD=0
bbMPEG VBR=1
bbMPEG Pad VCD=0
bbMPEG Write PEC=1
bbMPEG Add Scan Offsets=1
bbMPEG Align Sequence Headers=1
bbMPEG Use Private Stream 2=0
bbMPEG Computed Bitrate=1
bbMPEG TimeStamps=0
bbMPEG Pulldown=2
bbMPEG MuxRate=0
bbMPEG Pack Size=2324
bbMPEG Packets Pack=1
bbMPEG Video Buffer=230
bbMPEG Audio 1 Buffer=4
bbMPEG Audio 2 Buffer=4
PBCType=0
Use LastCD Picture=0
Use EntrySVD=0
Save XML=1
Save Movie Info=1
ProcessPriority=1
Automatic Shutdown=0
[Executables]
vStrip Executable=C:\Program Files\DVD2SVCD\vStrip\vStrip.exe
DVD2AVI Executable=C:\Program Files\DVD2SVCD\DVD2AVI\DVD2AVI.exe
SubMux Executable=C:\Program Files\DVD2SVCD\WinSubMux\WinSubMux.exe
MPG2Dec DLL=C:\Program Files\DVD2SVCD\MPEG2Dec\mpeg2dec.dll
InverseTelecine DLL=C:\Program Files\DVD2SVCD\InverseTelecine\Donald Graft\decomb.dll
SimpleResize DLL=C:\Program Files\DVD2SVCD\SimpleResize\SimpleResize.dll
Pulldown Executable=C:\Program Files\DVD2SVCD\pulldown\pulldown.exe
BeSweet Executable=C:\Program Files\DVD2SVCD\BeSweet\BeSweet.exe
MPEG51 Executable=C:\Program Files\DVD2SVCD\MPEG5.1\pub_enc.exe
bbMPEG Executable=C:\Program Files\DVD2SVCD\bbMPEG\RunbbMPEG.exe
VCDImager Executable=C:\Program Files\DVD2SVCD\VCDImager\VCDImager.exe
VCDXBuild Executable=C:\Program Files\DVD2SVCD\VCDImager\VCDXBuild.exe
Title Picture=C:\Program Files\DVD2SVCD\DefaultTitlepicture.bmp
Change CD Picture=C:\Program Files\DVD2SVCD\DefaultChangeCD.bmp
Last CD Picture=C:\Program Files\DVD2SVCD\DefaultLastCD.bmp
PVA Executable=
CDMage Executable=
RunPerCDImage Executable=
RunFinal Executable=
Subtitle DLL=C:\Program Files\DVD2SVCD\Avisynth Subtitler.dll
BMP Loader DLL=C:\Program Files\DVD2SVCD\Avisynth BMP Loader.dll
VFAPI Executable=C:\Program Files\DVD2SVCD\VFAPI\Reader\VFAPIConv-EN.exe
MadPlay Executable=C:\Program Files\DVD2SVCD\MADPlay\madplay.exe
CCE Executable=C:\Program Files\Cinema Craft Encoder SP\cctsp.exe
TMPGEnc Executable=C:\Program Files\TMPGEnc 2.56.39.143 Plus\TMPGEnc.exe
I-Author Executable=
Dividee MPEG2Dec=C:\Program Files\DVD2SVCD\MPEG2Dec\mpeg2dec.dll
[Folders]
vStrip Folder=G:\My DVD Data\Movies\DVD-SVCD Output\
DVD2AVI Folder=G:\My DVD Data\Movies\DVD-SVCD Output\
Audio Folder=G:\My DVD Data\Movies\DVD-SVCD Output\
CCE Folder=G:\My DVD Data\Movies\DVD-SVCD Output\
Pulldown Folder=G:\My DVD Data\Movies\DVD-SVCD Output\
Subpictures Folder=G:\My DVD Data\Movies\DVD-SVCD Output\Subs
bbMPEG Folder=G:\My DVD Data\Movies\DVD-SVCD Output\
I-Author Folder=G:\My DVD Data\Movies\DVD-SVCD Output\
PVA Folder=G:\My DVD Data\Movies\DVD-SVCD Output\
TMPGEnc Folder=G:\My DVD Data\Movies\DVD-SVCD Output\
[AVISYNTH_BilinearResize]
0=BilinearResize(^TargetWidth,^TargetHeight)
1=AddBorders(0,^BorderTop,0,^BorderBottom)
[AVISYNTH_SimpleResize]
0=LoadPlugin(!SimpleResize.dll)
1=SimpleResize(^TargetWidth,^TargetHeight)
2=AddBorders(0,^BorderTop,0,^BorderBottom)
!SimpleResize.dll=C:\Program Files\DVD2SVCD\SimpleResize\SimpleResize.dll
[AVISYNTH_InterlacedResize]
1=InterlacedResize(^TargetWidth,^TargetHeight)
[AVISYNTH_BicubicResize]
0=BicubicResize(^TargetWidth,^TargetHeight,^b_valu e,^c_value)
^b_value=0.0
^c_value=0.6
Problem DVD Rebuilder Pro: Is not a ECL for CCE SP Trial Version
By Talayero in forum DVD RippingReplies: 2Last Post: 30th May 2008, 13:25 -
cce video bitrate problem
By DSLGuy in forum Video ConversionReplies: 11Last Post: 16th Feb 2008, 12:53 -
CCE OPV
By name123 in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2008, 12:03 -
best software for cce sp
By zookeeper525 in forum DVD RippingReplies: 12Last Post: 25th Dec 2007, 14:41 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 20:27
