I posted a message yesterday - got a reply from markrb-cheers for replying, he pointed me to the rules saying post up your log file-sorry, here it is-thanks again to anybody how can help us out:
dvd2svcd_log.txt
WNASPI32.DLL 4.6.0.1021
- 17/12/2002 20:07:03
- AVI to SVCD Conversion
- AVI2SVCD ver. 1.1.0 build 1c
Initializing
Initializing finished.
- 17/12/2002 20:07:07
- Free on drive G: 9066.83 mb
- AUDIO Extraction
Audio extraction finished.
- 17/12/2002 20:08:04
- Free on drive G: 8974.90 mb
- AUDIO conversion
Encoding Audio. Filename: G:\My DVD Data\Movies\DVD-SVCD Output\Extracted_audio_1.ac3
Executing BeSweet. Commandline:
"C:\Program Files\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "G:\My DVD Data\Movies\DVD-SVCD Output\Extracted_audio_1.ac3" -output "G:\MYDVDD~1\Movies\DVD-SV~1\Encoded_audio_1.mp2" -logfile "G:\MYDVDD~1\Movies\DVD-SV~1\Encoded_audio_1.log" ) -azid( -L -3db -c normal -s surround -g max ) -shibatch( --rate 44100 ) -2lame( -e -b 192 -m s )
Audio conversion of G:\My DVD Data\Movies\DVD-SVCD Output\Extracted_audio_1.ac3 finished.
Audio conversion finished.
- 17/12/2002 20:33:34
- Free on drive G: 8882.93 mb
- Video Encoding using Cinema Craft
(Then i gett a message in cce, saying:
Frame size 756x56 is not supported. Supported Frame size is up to 756x560)
Avisynth_Script_file.avs
LoadPlugin("C:\PROGRA~1\DVD2SVCD\MPEG2Dec\mpeg2dec .dll")
AVISource("G:\MYMUSI~1\JAMESB~1\007DIE~1.AVI",Fals e)
ConvertToYUY2()
BicubicResize(480,368,0.0,0.6)
AddBorders(0,56,0,56)
ResampleAudio(44100)
Thanks in advance for anybody who replys
I began converting some divx movies,to svcd using cce,but began getting strange results!The movie was fine-but had a purple haze over it!i put these movies aside but cant figure what im doing wrong-i though i might not hae the correct codecs installed so i made a stupid movie of uninstalling all my codecs,players etc - now it wont convert at all! My questions are below:
1.)
Im getting a message in cce
The codecs i haev installed are:
Nimo.Codec.Pack.5.Build.7. - Shareactor
XviD_Install - From Divx Digest
Aspi
ASPI32.SYS V4.6(1021)
WOWPOST.EXE V4.6(1021)
WINASPI.DLL V4.6(1021)
WNASPI V4.6(1021)
it also says:ASPI is properly installed and full operational
dvd2svcd v 1.1.0 Build C
cce 2.5 SP Version 2.50.01.00 (SDK Version ) (at he top of cce it says SP --noname)
I read somewhere you should have too many-are these enough?am i missing some/a lot?
I thought while waiting to get cce to work again i would us TMPG but that aint working now either it comes up with errors while encoding the movie something like "a00010181" and i need to click "OK" then another comes up-this continues-i dont know if that is another thing altogether!
2.)
My computer seems to play wav files i create using audio programs but when i try to rip the audio from a divx movie in virtual dub it comes up with an error:
The Requested audio compression is not compatible with the input formate.Check that the sampling rate and channel count of the input match of the requested format
In roxio it i split the audio&video but it seems to not know what wav file is. In sound forge it said the wav file is unsupported!
Im following tutorials exactly i think im missing something have been stuck with this problem for ages. Can any experts out there help me out with a solution?Cheers again
Results 1 to 1 of 1
Product for Putting a Head on an Animated Body?
By shira in forum Newbie / General discussionsReplies: 4Last Post: 2nd Jan 2011, 17:10 -
ps3 and Body of Lies blu ray
By rubberman in forum DVD & Blu-ray PlayersReplies: 1Last Post: 16th Mar 2009, 12:10 -
Body Glove Case ruining DVDs?
By jwnulife in forum MediaReplies: 6Last Post: 10th Feb 2008, 19:21 -
Any body know to delte the ACrros using A MacOS X?.
By vriosm in forum MacReplies: 2Last Post: 8th Nov 2007, 07:55 -
Any body interested in letting me put your videos on my site
By goheadtry in forum Newbie / General discussionsReplies: 0Last Post: 3rd Sep 2007, 14:03
