I have a DVD that is currently an AVI file. It is in PAL DIVX format at 720x416 at 25 F/sec. I'm located in the US. I want to convert it to VCD. Question is, with that ratio, should I convert to NTSC or PAL? Here is my thoughts. You have the AVI file at 720x416. Half of that would be 360x208. A NTSC VCD file would be 352x240 and a PAL VCD would be 352x288. By those measurements, I would gather that there would be less of a stretching effect with the NTSC over the PAL format. Would this be accurate? Also, can you make a VCD that conforms to the ratio of the original encoded file, which is then out of spec for the VCD format, and if so, what would be a ratio I would utilize for this particular AVI file? Thanks.
Results 1 to 1 of 1
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 09:55 -
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 15:17 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19
